Network Communications Problems
I am have real problems keeping the communication alive between NIs and touch panels and between NIs and my RMS server (about 60 systmes). When I check the NI what I usuall find is something like this with "TCP LIST"
The following TCP connections exist(ed):
1: IP=172.23.100.151:1028 Socket=30 (Active)
2: IP=172.23.100.151:1079 Socket=0 (Dead)
Although, most of the time all I find is (Dead). This happens on connections to external devices and to telnet. It even sometimes happens to network connection itself and I have to go in via RS232. I should also mention that the system that crashes the most is an NI-700 running the AMX-Extron-RMS software.
All of the systems are running v3.21.343. Is there a way to make TCP connections more robust? Would the newer firmware help anything?
My systems are on a campus network that has been going through transitions. The main one change is moving from Linksys layer one switches to HP procurve layer 3 switches and adding a Bradford network control system on top of that. We have also been having real problems with Spanning Tree broadcast storms but those storms don't seem to be at the same time as the control system lockups.
What we had to do was work with one of the network admins and have them watch us as we worked with the Netlinx master and show them when things worked and when they didn't. We were eventually able to get the switches and firewalls set correctly. It took quite a lot of work, however.
