AMX File System
Is there any way to flag files on the processor as protected so they cannot be easily deleted? Would this also apply to usage of the clean disk command if such a thing exists? :)
    Spire_Jeff wrote: »
    I found out by accident that if you start the file name with a dollar sign ($) the file can?t be deleted unless you issue a format/clean disk command.
    Joe Hebert wrote: »
    I believe that is standard Unix behavior.
