IR Blaster - Toshiba
We have some installations wit new Toshiba H83 & H93 RP TV's . The IR recievers are behind the screen,. We can open them and put emitters inside, but I would rather use a blaster, we have used Xantech blinkI emitters but the are not "Blasters'. Does anybody have a high output emitter they can recommend ?
  • I did a system not too long ago that used a Niles Audio IRP2+ amplifier and an IRC1 high-output "flooding" emitter to control a projector that was on the opposite side of the room from the control system. (Client insisted that he simply could NOT pull any more wire over)
    I'd imagine this would do the trick, but I would think the time involved in popping the cover on that unit to put a regular emitter inside the case would be prefferable to the expense of the amp/emitter combo.
    - Chip
    Speakercraft makes an IRE5.0 IR Blaster and I know that it works on the Samsung DLP.
