extron switcher mps 112 problem
I m not able to control the extron switcher thru the amx touch panel.
The rs 232 is working because thru notifications i can send and recieve the messages
i have defined the device
dvExtron =5001:2:0
dvTpExtronMVP7500 =10001:2:1
and my extron code is
PROGRAM_NAME='IncExtron'
DEFINE_VARIABLE
INTEGER Index
char Sbuff[40]
INTEGER nExtronbutton[] =
1,2,3,4, // VGA
5,6,7,8, // S- video
9,10,11,12 //video
DEFINE_START
create_buffer dvExtron,Sbuff
DEFINE_EVENT
DATA_EVENT[dvExtron]
online:
// Set Baud for Projector
send_command dvExtron,"'SET BAUD 9600,N,8,1'"
BUTTON_EVENT[dvTpExtronMVP7500,nExtronbutton]
push:
Index = GET_LAST(nExtronbutton)
SWITCH(Index)
CASE 1:
// VGA
send_string dvExtron,"'1!'"
break
CASE 2:
// VGA
send_string dvExtron,"'2!'"
break
CASE 3:
// VGA
send_string dvExtron,"'3!'"
break
CASE 4:
// VGA
send_string dvExtron,"'4!'"
break
CASE 5:
// S-video
send_string dvExtron,"'5!'"
break
CASE 6:
// S-video
send_string dvExtron,"'6!'"
break
CASE 7:
// S-video
send_string dvExtron,"'7!'"
break
CASE 8:
// S-video
send_string dvExtron,"'8!'"
break
CASE 9:
// video
send_string dvExtron,"'9!'"
break
CASE 10:
// video
send_string dvExtron,"'10!'"
break
CASE 11:
// video
send_string dvExtron,"'11!'"
break
CASE 12:
// video
send_string dvExtron,"'12!'"
break
i think the code i m sending to the extron switcher is not recognized by it
can anyone help me in this ,this is my first program.
    I think you need to put a CR and/or LF at the end of the string
    example
    CASE 1:
    // VGA
    send_string dvExtron," '1!',$0d,$0a "
    break
  • Double check that your port actually went to 9600. Send a command to the port with control a device in diagnostics. The command is GET BAUD. Every once in a while, even when the processor says the port is online, It's not ready to receive a SEND_COMMAND. Extron commands don't need a CRLF.
  • jweatherjweather Posts: 320
    Make sure it's in single-switcher mode by sending 1*1# (or via front panel config). Then it should switch via the 1! commands.
    It may also be necessary to put a CHARD command on that port. As I recall, the unit is really only looking for single bytes, and if they come in too fast it may not recognize the command.
  • the extron switcher was not in the single switcher mode ,so once i change it to single mode.the extron started recognizing the commands thru rs 232
    thanks to all for your help
    Really? Is this a known documented bug? Has AMX confirmed this issue and are they working on a fix?
    Does this problem exist for SEND_COMMANDs to any device in its ONLINE: handler or is it strictly an RS-232 port problem?
  • I never reported this as a bug. It happens so sporadically I never thought to follow thru with it... Ajay just needs to confirm that the port actually changed to the proper settings.
