NI-900 and Axcent 3 (slave mode)
Hey you all!
I'm put a NI-900 as master and the Axcent as slave ... so every command work fine when I send with the terminal in Netlinx Studio ... but when I ran the programm sometimes the commands fail, I worked with Axcess several years ago ... I made the program like I make with only Netlinx systems, I need to change something? Put delay between the commands or something like that?
Thank you all!
Thank you all!
Perhaps you can be more specific with what you mean when you say that it sometimes fails. I've never seen any problem with slaving an Axcent 3.
When an Axcess master is set to slave mode the first device is no longer 1. It becomes 1+the SET BASE DEVICE NUMBER. So if you set the base device number to 1 the first RS-232 port becomes DEVICE 2. This through me off for a while on a project some years back.
after some time the NI-900 would fail to receive input from the Axcent 3 (the input LED didn't light up, even when data was being sent from Axcent 3)
We have replaced the NI-900 with a NI-700 and all is well now
