Home AMX Technical Discussion
IR File for JVC SR-DVM700
Does anyone have an IR file for the JVC SR-DVM700-US? Customer switched gears on us, at first they wanted this unit in the design then dropped it due to budget changes. The designer dropped system down to a NI-2100 because less ports needed. Now the customer wants to add it back in and only port available is IR and no budget to do anything else...
Thanks in Advance...
Robert
  • yuriyuri Posts: 861
    one way serial? :)
  • Not Sure
    I am concerned about the reliabilty based on other comments I have seen here about distance etc... Deck and control sys are about 100' apart...
