RS232 and HEX
How can I assign a hex command string to a variable or constant and the transmit it? I tried putting this statement under the define_constant section:
dvProjVidInput = "$02,$41,$44,$5A,$5A,$3B,$49,$49,$53,$3A,$56,$49,$44,$03"
And then send it with:
SEND_STRING dvProj, dvProjvidinput
I am seeing $02,$41,$44,$5A,$5A,$3B,$49,$49,$53,$3A,$56,$49,$44,$03 out the comm port but if I do this:
SEND_STRING dvProj, "$02,$41,$44,$5A,$5A,$3B,$49,$49,$53,$3A,$56,$49,$44,$03"
it works... What am I missing?
Should be as
ProjVidInput[] ={$02,$41,$44,$5A,$5A,$3B,$49,$49,$53,$3A,$56,$49,$44,$03} Send_String dvProj, ProjVidInputDefine_Constant is fine for this
INTEGER CAM1_COMMANDS[][]= { {$FF,$01,$88,$88,$25,$35,$6B} // UP ,{$FF,$01,$88,$90,$25,$35,$73} // DOWN ,{$FF,$01,$88,$84,$35,$25,$67} // LEFT ,{$FF,$01,$88,$82,$35,$25,$65} // RIGHT ,{$FF,$01,$88,$C0,$25,$00,$6E} // TELE Wide ,{$FF,$01,$88,$A0,$25,$00,$4E} // TELE Zoom ,{$FF,$01,$00,$00,$00,$00,$01} // STOP } } SWITCH(nSOURCE[nTP_NUM]) { CASE 25: { IF( BUTTON.INPUT.CHANNEL=50 OR // tele wide and tele zoom need a stop to make press and hold work BUTTON.INPUT.CHANNEL=51) { SEND_STRING dvEquipPelco,"CAM1_COMMANDS[BUTTON.INPUT.CHANNEL-45]" SEND_STRING dvEquipPelco,"CAM1_COMMANDS[7]" } }Thanks Guys!! I knew it was something simple on my part that was amiss.
