Mvp 8400 Falling Offline
I have a MVP 8400 that is falling off line almost every evening, and definitely every weekend. I have instructed the customer to powerdown the rack ( NI 3000, and Linksys 802.11b router in the rack ), and then the panel is back online and every thing works again. The System consists of the NI 3000, Linksys 802.11b 4 port router ( Static ips for panel,master and local PC running AMX computer control, latest firmeware in master ,TDS, and MVP),and an MVP TDS. To trouble shoot I have 1: turned the Panel Shutdown to 0 in the MVP so the panel will never shutdown. ( they keep it docked always so batteries draining is not the issue ) 2: provided a button on the first page of the panel tied to a Data_Event to match the online/offline state of the Panel. When the panel is offline the button correctly displays the offline state. Friday I was on site to witness the problem ( system not working and button on panel correctly indicated the panel was offline) and a reboot of the Router ONLY fixed the problem. So I was really thinking router problem, but left the system status quo and working Friday night to see if the problem was still fixed by rebooting the router only. I heard Monday that the panel was off line as usual Monday morning, they rebooted the router ONLY, waited 3 minutes, and the panel DID NOT come back online. They had to powerdown the rack ( which again rebooted the master and router ), then the panel was online. Is it still the router? I am leaning towards the router, but could it somehow be the panel or the NI?
Excess network traffic is far more critical when you add wireless to the mix, and crops up again and again as a trouble spot for me.
Two things, first... I Have had nothing but trouble with Linksys routers and access points. The problems with them are compounded when you have multiple access points on the network. So, I would definately be suspect of the Linksys device (you might try getting the latest firmware from Linksys)
As for packet sniffing, you have to be careful of how you are sniffing the packets. If you are sniffing from a switch, you will be missing a lot of the network traffic (Unless you have a higher end switch that lets you send all traffic to a specific port). To get a true picture of the traffic, the easiest thing to do would be to temporarily replace the switch with a hub and run the packet sniffer.
