MVP8400i panels lockup/white screen problem
 avosystems
avosystems
                                  in AMX Hardware
                    Hi
I have a project with 3 mvp8400i panels which are are randomly locking up and white screening until the batteries are removed and the panels reset. There is also a CV5 panel which has worked perfectly on the same system (though the layout etc is a bit different).
I have tried moving the panels round the house in the different locations to see if it was a specific panel, or a specific position but that doesn't seem to make a difference as they all go to the white locked up screen in all positions. (though sometimes it can be weeks with out a problem, and other times days)
I have tried removing all feedback from my mainline to make sure it's not too much feedback data being sent to the panels but this hasn't cured it.
I have also tried removing a imerge module that I thought could be the problem as it sends a fair amount of data out but again that has not cured the problem.
I though maybe wireless signal dropout, but my distributor doesn't think that would be the case, and I would think the panel would handle going on and off the wireless without a problem.
Anyone got any ideas or experienced anything similar as my customer is starting to get very annoyed with the situation and I am running out of ideas as to what is causing the problems?
I really appreciate any help or advice you can give me.
It does seem like a strange turn of events.
By chance do you have Dynamic Images on your TP?
or
I doubt this could happen to all three, but have they been dropped (maybe the bezel is touching the screen) I had that happen to one panel it locked out any other commands
or
Have you called AMX?
I do have some dynamic images from a Axis video server displayed on a popup page that have a 1 sec refresh rate (cctv cameras), but these aren't up very often and I thought that they only requested the images when the page was up?
I have contacted our distributor about the problem but we don't seem to have been able to figure it out with them yet, maybe I should try AMX direct like you suggested and see if I have any joy.
I have had issues in the past when there are conflicts with Dynamic Images. I still think your best bet is calling AMX.
Wow, everyone gave them such stellar reviews over in the 'rate the reliablitity' thread. These are the kinds of problems I've been having myself. At least I know I'm not going crazy now.
I think you have raised a good observation....
The same thing happens when the Master seeks out IP information. If it doesn't receive it right away it can hang up quite a few processes.
--John
This is actually an inherent problem with all AMX devices and IP connections. There must be a common IP library they are using that has this fault; even their software tends to crash and burn if an IP connection is delayed or interrupted in the process of connecting.
I see this a lot more often with TPD4. If you're uploading panels directly from TPD4 and fail to remember to disconnect from the panel, and then upload a new program to the netlinx master you're working, thus severing the connection from TPD4 and the master, TPD4 will crash. (for extra credit: diagram the previous sentenece...)
I've always wondered about this phenomenon with AMX stuff. It would seem a simple trap to fix in my mind. Perhaps not.
I have seen much less of this lately. I've recently labotomized my PC and am running the second-latest version of TPD4.
In my little world....
NS2 doesn't crash very often. When it does there seems to be no rhyme or reason.
TPD4 crashes with regularity and is very predictible. It's almost always after a disconnect from the master coming from something else than TPD4. I can predict it happening too. Once the disconnect has happened, I can do 3-4 more major things and it crashes.
IREdit crashes occasionally from the same kind of thing, a master disconnect. IREdit also does an extremely annoying thing when you're browsing the device tree o' IR files. If you scroll up to somewhere in the middle, say Runco and hit the folder to open it, the list jumps all the way to the end of the whole window. I've learned that it's going to do this everytiime you open a new brand folder. Once you let it do that it will not jump again untiil you select a new brand. wash-rinse-repeat.
It won't respond to touches or external buttons.
The installation is in a wall docking station that is out of wireless range. So the panel is offline for long periods of time. Sometimes days.
I may try to move it into wireless range to see if this stops the lockups.
This was where the customer wanted it placed. It is never used while in the docking station.
