Landmark Upgrades
Hi Peoples, I could do with some advice please. I currently have four sizeable Landmark customers concerned about the now obsolete Landmark to NetLinx upgrade path (and when I say sizeable I mean large systems - 42 DMS keypads in one of the houses and 40 - 60 movement sensors in each!).
All four clients are technically literate meaning they like to manage their own systems to a large extent which Landmark is perfect for them.
NetLinx and associated equipment is marvelous but so far I not been able to find a GUI replacement solution that allows the client the same drag and drop control and flexibility without getting into text programming.
Any suggestions?
Any suggestions?
NetLinx has really helped in this regard as it is just so flexible from a control point, but will need to put some serious work on the customer GUI. TPD4 is great in this regard but once again, clients can't just create a room/Area, whack in a keypad, light cicuit, relay and some parameters and they're done. Case in point, a client I've recently upgraded to NetLinx wanted to add another irriagtion area with a couple of relays, and was dissapointed he couldn't do it himself as he used to do with Landmark. Playing audio files is another hurdle - Landmark handled all that but NetLinx is very different - it can be done easily enough - just not by the client (yet).
I will ponder this and a great many other things over a whiskey or two whilst on holiday.
You have a great New Year!
