help with the netlinx /singel step function
hai,everyone
i have just begun use the netlinx programme.i want to use the debugging function .but when i use the single step ,it doesn't work .
According to the use manual of the netlinx, it should be work ,i have alread set the breakpoint and TKN document on the NI-700 master verify with the one now i'm debugging ,I really don't know why ,
please help
every one
  • nobody can help me ,i know it's a stupid question, but i really want to know it
    Post the code and perhaps we can help. It's hard to work with so little information.
  • i think it's a not code problem,because the code compile and execute well,i think perhaps the problem is the setting of the netlinx.
    the code is upload but i think it's too big to read it.it's not easy work.
    thanks for respond .
    In NS2 > Settings > Preferences > Netlinx Compiler > under the options section is the check box for "Compile with DeBug Info" checked. If not check it.
  • vining wrote: »
    thanks ,vining ,i have got it ,thanks it really work
