ASTRO_CLOCK?
Could someone post an example for the usage of ASTRO_CLOCK? Should I put this in define_program? I need sunrise & sunset times everyday to manage some lighting controls.
  • AMXJeffAMXJeff Posts: 450
    Use i!-TimeManager
    http://www.amx.com/products/i!-TimeManager.asp
    You get a button event when Sunrise or Sunset time has been reached. (Of course you got to make sure your latitude/longitude settings are correct)...
    (* BUTTON_EVENT: Sunrise Channel                           *)
    (* PURPOSE:      Channel is pushed (and turned on) when    *)
    (*               the Sunrise occurs                        *)
    BUTTON_EVENT[vdvTmEvents,nTmSunriseChannel]
      PUSH:
        SEND_STRING 0,"'Sunrise occured at ',TIME"
    (* BUTTON_EVENT: Sunset Channel                            *)
    (*               the Sunset occurs                         *)
    BUTTON_EVENT[vdvTmEvents,nTmSunsetChannel]
      PUSH:
        SEND_STRING 0,"'Sunset occured at ',TIME"
    // full code
    (*  AMX Corporation                                                  *)
    (*  Copyright (c) 2000 - 2005 AMX Corporation. All rights reserved.  *)
    (*   please refer to EULA.TXT for software license agreement         *)
    (*                      i!-TimeManager  (1.0.11)                     *)
    PROGRAM_NAME='i!-TimeManagerTest'
    (*{{PS_SOURCE_INFO(PROGRAM STATS)                          *)
    (*  ORPHAN_FILE_PLATFORM: 1                                *)
    (*}}PS_SOURCE_INFO                                         *)
    (*          DEVICE NUMBER DEFINITIONS GO BELOW             *)
    DEFINE_DEVICE
    vdvTmEvents       = 33001:1:0
    dvTmTimeSync      = 0:3:0
    (*               CONSTANT DEFINITIONS GO BELOW             *)
    DEFINE_CONSTANT
    (* Timeserver protocols *)
    nProtoNone        = 0
    nProtoDaytime     = 1
    nProtoTime        = 2
    nProtoSNTP        = 3
    nProtoSNTPBCast   = 4
    (* Channels *)
    nTmSunriseChannel     = 1
    nTmSunsetChannel      = 2
    nTmDstChannel         = 3
    nTmTimeChangeChannel  = 4
    (* Levels *)
    nTmGmtEffLevel        = 1
    nTmGmtLevel           = 2
    nTmLongLevel          = 3
    nTmLatLevel           = 4
    (*              DATA TYPE DEFINITIONS GO BELOW             *)
    DEFINE_TYPE
    (*               VARIABLE DEFINITIONS GO BELOW             *)
    DEFINE_VARIABLE
    (* Timezone *)
    CHAR    dTmTzName[100]
    CHAR    dTmTzDesc[10]
    DOUBLE  dTmTzGmtOffset
    CHAR    strTmTzDstRules[1000]
    (* Location *)
    CHAR    strTmLocName[100]
    DOUBLE  dTmLocLong
    DOUBLE  dTmLocLat
    (* Timeserver *)
    INTEGER nTmTsProtocol
    INTEGER nTmTsCheckTime
    CHAR    strTmTsServer[100]
    (*           SUBROUTINE DEFINITIONS GO BELOW               *)
    (*                STARTUP CODE GOES BELOW                  *)
    DEFINE_START
    (* Step 1 - Configure the timezone:                        *)
    // Configure Timezone
    // Parameter 1: Timezone Name.  ex: "Eastern"
    // Parameter 2: Timezone description.  ex: "E%sT"
    // Parameter 3: Timezone GMT offset in hours.  ex: -5.0
    dTmTzName     = 'Central'
    dTmTzDesc     = 'C%sT'
    dTmTzGmtOffset = -6.0
    // Configure Timezone Rules *)
    // Parameter 1: Daylight savings string.  ex: "None", "US" or custom.
    // Custom string: "Month" "DayDescription" "Time" "Offset From Std" "Descrption"
    //                "Month":          Month name ex: "Apr"
    //                "Time"            Time to activate (hh:mm:ss, 24 hour).  ex: "02:00:00"
    //                "Offset From Std" Time to offset from GMT (hh:mm:ss, 24 hour).  ex: "01:00:00"
    //                "Description"     String to replace "%s" with in Timezone description.  ex: 'D'
    //                "DayDescription"  Day Description. Fixed Date, Last Day Of Week or
    //                                  First Day of Week Before/After Date
    //                                  Fixed ex: "15"
    //                                  Last Day of Week ex: "LastSunday"
    //                                  First Day of Week Beforer DATE-ex: "Sun<=24"
    //                                  First Day of Week After DATE-ex: "Sun>=1"
    strTmTzDstRules = 'US'
    (* Step 2 - Configure Physical Location:                   *)
    // Configure Physical Location
    // Parameter 1: Location Name.  ex: 'Seattle'
    // Parameter 2: Location Longitude.  ex: -122.33 (>0 == East, < 0 == West)
    // Parameter 3: Location Latitude.  ex: 47.6 (>0 == North, < 0 == South)
    strTmLocName   = 'Dallas'
    dTmLocLong = -96.76
    dTmLocLat = 32.79
    // You can find longitude/latitude values and descriptions at:
    // http://geography.about.com/cs/latitudelongitude/
    // http://www.census.gov/cgi-bin/gazetteer
    // http://www.njdxa.org/landl-lookup-dx.shtml
    (* Step 3 - Configure Time servers:                        *)
    // Configure Time servers
    // Parameter 1: Protocol, 0=Disbaled, 1=DayTime(13/udp, 13/tcp), 2=Time(37/udp, 37/tcp), 3=SNTP(123/udp), 4=SNTP Broadcast (137/udp).  ex: 2
    // Parameter 3: Default Server.  ex: 'mytimeserver.mydomain.com'.  Leave blank to read from time sevrer file (time/nist_svr.lst)
    // Parameter 2: Check Time interval in seconds.  Use 0 for default (2 hours).  ex: 3600
    // Parameter 4: Prefered Index of Timeservers in list.  ex: 2
    // Notes:       If parameters 3 is supplied, parameter 4 is ignored
    //              If paramater 3 is an empty string and parameter 4 is 0, a default will be picked from the list is possible
    //nProtoNone       = 0
    //nProtoDaytime    = 1
    //nProtoTime       = 2
    //nProtoSNTP       = 3
    //nProtoSNTPBCast  = 4
    nTmTsProtocol   = nProtoSNTP
    nTmTsCheckTime  = 0
    strTmTsServer   = ''
    (* Alternate Manual Timezone configurations:               *)
    // These are shown for example purposes and represent information that is not guaranteed to be correct!
    // Here is an exmaple configuration for Santiago, Chile which is -4 hours behind GMT and observes Daylight savings starting
    // on the Saturday on or after October 9th at midnight (jump ahead 1 hour) and the Saturday on or after the 9th of March at midnight (jump back 1 hour)
    // and describes the time as "hh:mm:ss CST" or "hh:mm:ss CDT" depending on Daylight savings and is located at "33s27, 70w40":
    //dTmTzName     = 'Santiago'
    //dTmTzDesc     = 'C%sT'
    //dTmTzGmtOffset = -4.0
    //strTmTzDstRules = "'Oct Sat>=9 00:00:00 01:00:00 D',$FF,'Mar Sat>=9 00:00:00 00:00:00 S'"
    // AND
    //strTmLocName  = 'Santiago'
    //dTmLocLong = -70.67
    //dTmLocLat = -33.45
    // Here is an exmaple configuration for Sydney, Australia which is +10 hours ahead of GMT and observes Daylight savings starting
    // on the Last Sunday in October 2:00 AM (jump ahead 1 hour) and the Last Sunday in March at 3:00 AM (jump back 1 hour)
    // and describes the time as "hh:mm:ss EST" regardless of Daylight savings and is located at "33s52, 151e13":
    //dTmTzName     = 'Sydney'
    //dTmTzDesc     = 'EST'
    //dTmTzGmtOffset = 10.0
    //strTmTzDstRules = "'Oct LastSun 02:00:00 01:00:00 X',$FF,'Mar LastSun 03:00:00 00:00:00 X'"
    // AND
    //strTmLocName  = 'Sydney'
    //dTmLocLong = 151.22
    //dTmLocLat = -33.86
    // Here is the example configuration for London, England which uses GMT and observes Daylight savings starting
    // on the last Sunday in March at 1:00 AM (jump ahead 1 hour) and the Last Sunday in October at 2:00 AM (jump back 1 hour)
    // and describes the time as "hh:mm:ss BST" or "hh:mm:ss GMT" depending on Daylight savings and is located at "51n30, 0w10":
    //dTmTzName     = 'London'
    //dTmTzDesc     = '%s'
    //dTmTzGmtOffset = 0.0
    //strTmTzDstRules = "'Mar LastSun 01:00:00 01:00:00 BST',$FF,'Oct LastSun 02:00:00 00:00:00 GMT'"
    // AND
    //strTmLocName  = 'London'
    //dTmLocLong = -0.16
    //dTmLocLat = 51.50
    (*            THE MODULE CODE GOES BELOW                   *)
    DEFINE_MODULE 'i!-TimeManagerMod' mdlTM(vdvTmEvents,
                                            dvTmTimeSync,
                                            (* Timezone *)
                                            dTmTzName,
                                            dTmTzDesc,
                                            dTmTzGmtOffset,
                                            strTmTzDstRules,
                                            (* Location *)
                                            strTmLocName,
                                            dTmLocLong,
                                            dTmLocLat,
                                            (* Timeserver *)
                                            nTmTsProtocol,
                                            nTmTsCheckTime,
                                            strTmTsServer)
    (*                THE EVENTS GOES BELOW                    *)
    DEFINE_EVENT
      PUSH:
      PUSH:
    (* BUTTON_EVENT: DST Activity Channel                      *)
    (*               the DST rules affect a time change with   *)
    (*               a non-zero time offset (DST Active)       *)
    (*               Channel is release (and turned off) when  *)
    (*               a zero time offset (DST Inactive)         *)
    BUTTON_EVENT[vdvTmEvents,nTmDstChannel]
      PUSH:
        SEND_STRING 0,"'DST is now active: ',TIME"
      RELEASE:
        SEND_STRING 0,"'DST is now inactive: ',TIME"
    (* BUTTON_EVENT: Time Change Channel                       *)
    (* PURPOSE:      Channel is pushed (and pulsed) when       *)
    (*               the Time is changed by a communication    *)
    (*               with a time server.                       *)
    BUTTON_EVENT[vdvTmEvents,nTmTimeChangeChannel]
      PUSH:
        SEND_STRING 0,"'Time adjusted by time server.  New Time is ',TIME"
    (* LEVEL_EVENT:  Effective GMT Offset                      *)
    (* PURPOSE:      Level is sent whenever the effective GMT  *)
    (*               offset is changed.  The effective offset  *)
    (*               is the real GMT offset with DLS correction*)
    LEVEL_EVENT[vdvTmEvents,nTmGmtEffLevel]
      SEND_STRING 0,"'Effective GMT Offset=',FTOA(LEVEL.VALUE)"
    (* LEVEL_EVENT:  GMT Offset                                *)
    (* PURPOSE:      Level is sent whenever the GMT            *)
    (*               offset is changed.                        *)
    LEVEL_EVENT[vdvTmEvents,nTmGmtLevel]
      SEND_STRING 0,"'GMT Offset=',FTOA(LEVEL.VALUE)"
    (* LEVEL_EVENT:  Longitude                                 *)
    (* PURPOSE:      Level is sent whenever the longitude is   *)
    (*               changed.                                  *)
    LEVEL_EVENT[vdvTmEvents,nTmLongLevel]
      SEND_STRING 0,"'Longitude=',FTOA(LEVEL.VALUE)"
    (* LEVEL_EVENT:  Latitude                                  *)
    (* PURPOSE:      Level is sent whenever the Latitude is    *)
    (*               changed.                                  *)
    LEVEL_EVENT[vdvTmEvents,nTmLatLevel]
      SEND_STRING 0,"'Latitude=',FTOA(LEVEL.VALUE)"
    (* DATA_EVENT:   Strings for Sunrise/Sunset                *)
    (* PURPOSE:      parse strings for sunrise and sunset      *)
    DATA_EVENT[vdvTmEvents]
      STRING:
        STACK_VAR
        CHAR strUpper[30]
        CHAR strTemp[30]
        CHAR strTrash[30]
        strUpper = UPPER_STRING(DATA.TEXT)
        strTemp = DATA.TEXT
        strTrash = REMOVE_STRING(strTemp,'-',1)
        SELECT
          (* SUNRISE *)
          ACTIVE (FIND_STRING(strUpper,'SUNRISE-',1)):
            SEND_STRING 0,"'Sunrise Time=',strTemp"
          (* SUNSET *)
          ACTIVE (FIND_STRING(strUpper,'SUNSET-',1)):
            SEND_STRING 0,"'Sunset Time=',strTemp"
          (* TIME ZONE NAME *)
          ACTIVE (FIND_STRING(strUpper,'TIMEZONE-',1)):
            SEND_STRING 0,"'Timezone=',strTemp"
          (* TIME DESCRPTION *)
          ACTIVE (FIND_STRING(strUpper,'TIMEDESC-',1)):
            SEND_STRING 0,"'Time Description=',strTemp"
          (* LOCATION *)
          ACTIVE (FIND_STRING(strUpper,'LOCATION-',1)):
            SEND_STRING 0,"'Location=',strTemp"
    DEFINE_CONSTANT
    (*            THE ACTUAL PROGRAM GOES BELOW                *)
    DEFINE_PROGRAM
    (*                     END OF PROGRAM                      *)
    (*        DO NOT PUT ANY CODE BELOW THIS COMMENT           *)
  • jjamesjjames Posts: 2,908
    Ahh - very cool. Thanks for the pointer! It's my first time having to do something like this so I was completely in the dark.
    Much appreciated!
    DEFINE_VARIABLE
    VOLATILE astro_date[15] // date in mm/dd/yyyy format
    VOLATILE slong astro_result
    VOLATILE double astro_longitude=-80.06
    VOLATILE double  astro_latitude=33.0
    VOLATILE double astro_hrs_from_gmt
    VOLATILE Sunrise[8]
    VOLATILE Sunset[8]
    and then down in your code...
    (* And then run this when you want the value.  I run it just after setting the system clock at 4-ish AM in the morning.   After running the equation Sunrise and Sunset are populated with the correct values for that day.  *)
    astro_hrs_from_gmt=DST_FLAG-5 // eastern time zone
     astro_result=ASTRO_CLOCK(astro_longitude,astro_latitude,astro_hrs_from_gmt,astro_date,Sunrise,Sunset)
    The latitude and longitude are for Charleston, SC You have to convert Latitude and Longitude values from minutes and seconds to decimal.
  • mpullinmpullin Posts: 949
    jjames wrote: »
    lol @ pun.
