B&K Volume Control
We are controlling a CT300.3 and Ref50s2 on a job using rs232. When sending the volume commands we use a push and hold to ramp the volume. The problem is that it continues to ramp up the volume even after the button is released and can continue to dangerous levels. Any suggestions to work around this?
From the behavior you're describing, it's obvious that the processor takes a longer time to perform the volume change you're sending than the time you're allowing between repeats.
There are a number of ways to handle this. I would think the simplest way would be to adjust the repeat time slower and slower until you find a nice comfy setting that doesn't outrun the processor. If the RS-232 protocol accepts descrete volume settings and the rs-232 port on the audio processor doesn't mind being pounded on, you could handle the volume ramping speed in the AMX program by incrementing the value there and sending descrete commands, thus avoiding the whole ramp time thing in the processor.
You also might check the owner's manual and see if you can bump up the ramp speed on the processor as well.
just some ideas...
You can send descete volume levels as Eric mentioned but there's something else going on and it sound like you're queing commands in the ouput buffer faster than the master can send them out so you end up stopping and the master is still outputting it's buffered commands..
HOLD[2, REPEAT]: { SWITCH (nBTN) { CASE 105: { cBnK_Msg = "'(0,S,I,',itohex(nBnK_Ozone),'=24;)'"//master volume + break } CASE 106: { cBnK_Msg = "'(0,S,I,',itohex(nBnK_Ozone),'=C4;)'"//master volume - break }In the words of the AMX Zen masters, "The simplest way is the best."
(actually, I'm not into Zen...)
