Device Port Tracking
 ondrovic
ondrovic
                    is there a way to track which port on a touch panel is being used? Say if port 4 on a touch panel is being used? ex: 10001:4:0
In either case you would need to use the embedded object.
If you're trying to determine if a port has been defined then you would need to use a DATA_EVENT handler since if a port is defined it will generate an online event during start up so you could use that event to set a flag in an array like this:
DATA_EVENT[dvTPDevicePort]//IP or SERIAL COMMS { ONLINE: { nTP_PortsUsedArry[data.device.port] = 1 ; //other stuff ; } }I don't now what you would do with this but I suppose it might have its uses.
To determine what port initiated an event you could something like this:
BUTTON_EVENT[dvTPDevicePort,nBtnArry] { PUSH: { nCurrentTP_EventPort = button.input.device.port ; //stuff } }For level events use "level.input.device.port" & channels events use "channel.device.port".
What are you trying to do?
