Problems Controlling Marantz SR8002 Receiver
i have installed a marantz sr 8002 receiver on rs 232 with netlinx ni-3100 controller. when i try to send the power off command on the receiver it behaves properly and switches the unit into standby but when i again want to switch on the unit using rs232 commands it does not switch on and respond.
kindly let me know if anyone has a similar problem.
The newer Marantz stuff has an annoying 'engergy saver' function. The idea is that when it's 'off' it's really 'off.' You have to manually switch on the power. Once it's on it will function normally.
I don't have the manual or codes in front of me. But there are a set of commads to tell it to operate normally (Go into standby, now power off). I generally send these commands whenever I send the power off command. However, if there is a prolonged power outage, the unit will revert back to default settings and the client will have to power the unit up manually.
No, I send the two commands that put it in non-economy mode. It's just a redundancy. If the unit has reset itself to factory, the client only has to power the unit on manually once. When they hit the system off button, the commands to put it back into non-earth friendly mode are resent. If the unit is already there, then nothing changes.
Here again, I'm not in front of it now but I think the standby command is something like @PWR:0 or something like that.
You have commands that can set normal standby vs. economy standby? Are you sure about that?
I see nothing in the protocol document that allows that or for that matter even mentions anything about normal and economy standby. The only way I can see to do it is by configuring the unit through the menu as the user manual explains.
If such commands do indeed exist can you please post them as they will come in handy?
Here is a link to the RS-232 pdf:
http://us.marantz.com/SR8002_SR7002_RS232_Control_Spec_MAI_V100.pdf
e
If you really want to save money on device power, just make sure the dang thing will turn on if the plug is pulled out and put back in ... then we can just put it on a power relay and be done. This whole energy saver mode thing is just an annoying waste of resources.
