Serial command
Hi
I tried a small test with netlink studio, and I tink as it's correct but when I send command trought the TX led on port one dosen't lit why?
If the command are no good, the TX pilot should lit ?
PROGRAM_NAME='SNH2009'
(* DEVICE NUMBER DEFINITIONS GO BELOW *)
DEFINE_DEVICE
dv_MATRIX = 5001:1:0
dv_TP = 10001:1:0
(* THE EVENTS GO BELOW *)
DEFINE_EVENT
DATA_EVENT[dv_MATRIX]
ONLINE:
SEND_COMMAND dv_MATRIX, "'SET BAUD 9600,N,8,1 485 DISABLE'"
BUTTON_EVENT [dv_TP,1]
PUSH:
SEND_COMMAND dv_MATRIX, "'INPUT- INTERNAL TUNER,1'"
BUTTON_EVENT [dv_TP,2]
PUSH:
SEND_COMMAND dv_MATRIX, "'INPUT-INTERNAL TUNER,0'"
use send_string instead of send_command...
// try this
SEND_STRING dv_MATRIX, "'INPUT- INTERNAL TUNER,1'"
send_command speaks to the AMX device - therefore your online_event is fine.
But I'm sure as I tried before my post .... sorry, I'm confuse with the doc in module, they spoke about "send_command" and since Matrix is a product of AMX I tried send command too and I dont know why my first (send_string) test has don't work
Only one thing, after many hr of labour, I was confused ( lack experience). The real problem was my "Matser" controler!
It's run any program who use ip protocol to communicate with interface, (ie: Modero intercom) but when I asked for external command such as serial, relay or IR out the master never send thoses commands. I use a new master and now all work nice!
