Can't get button feedback to work
Guys I need some help.
Problem: I'm not parsing the projector message to get the power button feedback to work. Actually buttons do function but feedback is not changing, only stays in the off position. Below is a txt copy of code can some tell what's wrong..
Brian
Brian
A couple things. First one I'm not sure about. I think the DEFINE_COMBINE statment needs to happen in the DEFINE_START section. I could be wrong about that. Also, I don't think the last comma is needed or will work.
secondly and more importantly, I'm not sure why you're using the DEFINE_COMBINE statement at all. typically it is used to to combine more than one device (namely touch panels) However, you have only one touch panel in your program. So, there's really nothing to combine. There's really no benefit to doing this in this case that I can see.
So, if it were me, I'd ditch the whole combine_device thing and just speak directly to the touch panel.
Now, if you're trying to make your program more flexible and able to communicate to more than one panel at a time, I'd recommend you look at a device array instead. It has a lot more flexibility and gives you a whole host of information about the devices that you cannot get from a combined device.
here's an example.
If you look in the help file you can get a whole list of event handlers that will give you a whole raft of info that is useful.
Of course, as a real programmer, I tackled the problem at its hardest for about half an hour, tracing strings and vars and lines of code before it struck me.
Eric, I'm rethinking the Dev combine bit. There was a mvp7500 that was removed from the system.
Felixmoldovan....guess what! I didn't have a Border name for my Off state, So the only state the border stayed in was the On state which did have a Border name. Duh hence the reason the border didn't change. I should have caught it in button view. Man that won't get me again.
When I get back to the system I'll report back on the results
Thanks Guys
Brian
Line 44 (08:34:57):: String From [5001:1:1]-[%001 POWR 000000$0D$0D$0A]
then the line
IF(FIND_STRING(PROJ_BUF,"'POWR ',$0D",1))
will never be satisfied because there is data (000000) between POWR and $OD which means your PROJ_PWR variable will never get twiddled
You probably want this instead:
IF(FIND_STRING(PROJ_BUF,"'POWR '",1))
Also these two lines in define program:
SEND_COMMAND vdvTP,"'TEXT1-',PROJ_HOURS"
SEND_COMMAND vdvTP,"'TEXT2-',PROJ_TEMP"
should be wrapped inside of a WAIT or put in a TIMELINE.
Please elaborate. I'm having issues with feedback on multiple panels right now.
I noticed I never reported back on this original post. I did get this system working correctly, Jon hit it right I was pasing Left_string when is should have been Right Also I noticed that had I properly managed the data from the projector either method would have worked
Sorry for late report seeing it on the list jogged the old memory bank
Brian
