Relay Control
I'm new with VA and have some questions. First, since this forum doesn't appear used much, is this the best place for questions?
Is there a way to place relay and/or I/O devices in the system diagram to represent that part of the system?
We have had that request and will be adding something to facilitate these types of devices in the future. For now, you can just add a Device Discovery I/O or Relay device but you will not be able to show a system connection. This would at least get something into the bill of materials. For functionality, this is no problem as you may program the closure in CodeBuilder under any button push. For instance, if you had a relay controlled screen, you could add a DD motor device and then program the functions under the up/down buttons on the page.
I hope this helps.
