Home AMX Technical Discussion
Bacnet Gateway
Hello,
I'm trying to control a Bacnet Gateway trough IP. It is a D-BACS gateway from Daikin to control a VRV system. Does anyone ever did someting with that?
I know that there is a company in Australia that did, and that way I know is possible.
  • bcirrisibcirrisi Posts: 148
    I have a job coming up next year that requires it, I talked to tech support and they told me that I would need to convert BACnet to Modbus (using something like this: http://www.csimn.com/CSI_pages/BBIPXM.html). Then they have a Modbus module, go to search third party devices and type 'modus; in the manufacturer section and you will see the module.
    I also believe this has been discussed in the forums before, so you might want do a search for BACnet in here.
  • roognationroognation Posts: 138
    You may want to peruse:
    http://amxforums.com/showthread.php?t=3767
    roognation
  • KrondorKrondor Posts: 14
    As far as i know they already have a direct Daikin- Modbus Gateway, and paln to release soon a Daikin - Ethernet direct solution..
