Factory Defaulting TPI/4
Greetings,
I have a TPI4 in which the 1988 password has been removed. Does anyone know of a non-removable password in or any other way to factory default the unit?
    I think only the factory can do that.
  • shr00m-dewshr00m-dew Posts: 394
    Does the master code from G3 panels work on G4's?
    Kevin D.
    I don't remember the G3 master codes. Any ideas?
    Can't find where I wrote it down right now..
    I did find this:
    SEND_COMMAND dvTP,'^PWD-5,1988' Panel will need to be online.
    Edit: Found it... 1205. Some say its works on G4, others don't.
    Kevin D.
  • 1205 will NOT work in G4 panels.
    Well, that was easy.
    Pressing the touch driver button on the front of the TPI4 got me into protected setup without a password. I was then able to change comm settings to match my system. I sent the PWD command and I'm good to go.
