MVP 7500 firmware
hello amx world.
I have a problem with panel MVP7500.
the CF is corrupt after upgrade firmware failed.
I know that through linux it is possible to copy the data from CF to CF but I do not have the data to copy.
what I must make?
thanks
Niccol? Garolini
Turin, Italy
ACUSON S.R.L.
    You need to get a CF card replacement from AMX if you don't have the data. If you have a working 7500, you could image the card from that and load it on the CF of your choice. If you have to get it from AMX, I would make a backup image. I use WinHex for such things and a generic card reader, and it's saved my bacon a few times already with CF glitches.
