Gotta be the dumbest 5200i question ever
I'm busy programming for a new 5200i that I don't have yet, and I have one really, really dumb question....
Where in the heck can I find the channel/level codes for the spinwheel?
I must be brain dead, but I can't for the life of me find them in the Operation Reference Guide, or the Installation Guide, or the PI's.
Should I give it up and become a ******** Programmer? (Just kidding, of course)
Thanks for any help.
Chuck
Chuck
...or double-click "External Controls" from the workspace tree.
Chuck
- set "level control type" to "relative"
- set "level code" to a desired level
- set "level control value" to anything you like. For instance 5
for rotate left:
- set "level control value" to anything you like, with a "-" sign in front. For instance -5
If you move the spinwheel, your level gets updated with the value you entered in "level control value"
Which, for the sake of completeness, can be done with any button. It's a good technique for having hardware buttons ramp an on-screen display level, for example.
Thats a really got way to do it. I hadn't thought about approaching from that angle in the past. Thanks.
I had one of those also. The reponse from AMX (& the forum) was that you push and hold the button, and it will go through the following process:
Setup
Calibration
Soft Restart
Hard Reboot
The last one takes about a minute if I remember, the duff panel I had didn't ever reach this stage...I once held the button for nearly 5 minutes and was tempted to film it and send it to anyone who said I hadn't held it long enough!!!
Dont forget the packed lunch and also the french maid to tidy up afterwards.....
Damien
