WAP250G offline . . . .
                                  in AMX Hardware
                    I have a client whose MVP8400 keeps dropping offline.  When it does, rebooting the panel does no good, I have to reboot the router.  This is a problem, because the router is located in the ceiling.
In the past, whenever I've had this problem, I've always been using a linksys WRT54G router, and upgrading to a WAP250G solved the problem. However, this job already has a WAP250G, so I'm at a loss. Has anyone run into this? What do you do to keep the panel connected?
J
J
I have had repeated problems with NI masters and the Linksys Wxxxxx routers. Tech support is aware of it. There is apparently some incompatability with the NIC card on the NI and the router/switch. I'd be willing to bet that the panel is not the problem. Try putting in a new router/switch and I'd bet the problem goes away. I've tried Netgear and higher end Linksys or Cisco. Had much better luck. We also use a lot of Sonic Wall
Also, I'd not recommend the WAP250G. We were putting them in a couple years back. All but 2 of them have burned themselves up. I beleive they have a heat dissapation problem. We've quit using them altogether. I'd highly recommend the Cisco Aeronet 1100. It's beefy, robust and darned powerful.
Ditto.
I've seen a number of units where the TP wouldn't reconnect with or without rebooting it and even cycling power to the WAP did no good. Pulling power and letting it cool down for a few minutes before putting the power back on would restore normal operation for an indeterminate period.
Suggest replacing the WAP as per Eric's advice.
