How Many IR Emitters on One Port?
in AMX Hardware
I have a system with many LCD TVs that have discrete power commands. All I need to do is turn them on and off. I would like to put multiple sets on one IR port. Does anyone have experience with putting multiple emitters on one port?
We do this all the time. However, one thing that we've seen as of late is that it's pretty important to make sure the LED emmitters are the same kind.
Our use this kind of thing was kind of incremental. I had a designer come to me at first and ask if it was possible. We tried it and it worked. Pretty soon their coming at me wanting 2 then 3 then 4. We found practicle upper limit of 3. However, I've made a rule of no more than 2. The programming involved with getting 3-4 to work is a bit of a headache
http://amxforums.com/showthread.php?t=2189
I understand that occasionally, you just need 1 more IR port, but in such a situation, I would either see if I can move one of the IR devices to be controlled via RS232 or IP. If that's not possible, I would explore the option of using an IP->IR adapter. Fortunately for me, I have not had to resort to the IP adapter and I can maintain standard AMX files thus far.
