Lutron Feedback
Hello,
I would like to ask the senior or clever juniors members
, about a problem I have with Lutron LEDs feedbaks.
I am trying to get the feedback from a Lutron system, but the KLS feedback strings don't containt the proper informations about the LEDs state. I can set the monitoring procedure (room,...etc) but I don't see when a phantom keypad button is ON or OFF.
Any help will appreciated,
Ion
Ion
??? can you see the LED state of the Luton feedback using hyperterminal plugged directly into the Homeworks processor? I've personally had pretty good luck with the Lutron module. It's pretty tried and tested and hasn't changed over the years.
Dearthe Eric,
My problem is that I don't know how to program Lutron to give me the right information. The button I am pressing can have the right state but I saw that also some buttons went on at the same time with pressed button. I don't know how to set the properties per keypadphantom's button.
Ion
Perhaps you can post some code and we can see if we can help.
e
make sure to put it between brackets so it's easier to read.
like this
You'll need to issue a command to the Homeworks panel to turn the KLS monitoring on. The command is 'KLMON'. Once the monitoring is on, when an LED changes state you'll receive a string notification as follows:
If you don't have access to the Homeworks info, implementing the AMX module might be easier since there's more documentation on it.
If you just need help parsing it, then posting your code will be helpful like Eric says.
--John
If so, you need to add only the lights you want to monitor to the button. You also have to set the LED logic to Room, Scene, or Pathway. If you search for those terms in the lutron help files, you should find a description of what each means.
also keep in mind that all keypads, phantoms or otherwise have 24 buttons and 24 LEDS. Ok they don't all physcally have 24 buttons but logically they do. On the Phantoms you'll see the physicall buttons 1-15 and 23,24. The KLS string returned will have 24 LEDS.
Dear all,
Thank you for you reaction, I was yesterday to tired to read all or your posts. I can parse correctly the Lutron strings but the problem is with the programming of the Lutron, I think. So after your messages I realize that I have to talk with the Lutron guy, who programmed the Lutron processor. I encounter a kind of situation that vining discribes.
Thank you a lot for your real-time help ....
Ion
One thing we do that really makes things much simpler is create virtual keypads/buttons for all the things that need to talk to AMX. It makes things easier for the Lutron programmer in that he doesn't have to constantly inform you of any changes made to the Lutron side of their program.
