Home AMX Design Tools
TP4 version 2.4 ERROR w/8400
I made the mistake of updating TP4 version 2.4 Friday night...
When trying to upload a panel design to a MVP-8400 using the new version of TP4 design, I get the warning:
"Chameleon Image: v2.50 required". It won't let me upload the panel design. Anyone know of a work around!
How can AMX update software without having the updates for the panels availible?
  • Were you trying to use the new aluminum smoke template? That would have to wait for the new 8400 firmware..
    Otherwise it sounds like a button got set to chameleon by accident.
    Kevin D.
  • GSLogicGSLogic Posts: 562
    I was testing how the chameleon button worked but deleted it and I still can't upload the panel, I even tried to delete all the Pages and Popups with no luck.
  • Apears you might have found a bug then. Perhaps in order to make sure nothing bad happened they flag the TP file when a chameleon button gets added. Maybe they never thought to unflag it when all chaneleon buttons are removed??
    Kevin D.
  • Originally posted by GSLogic
    If you could, please ZIP and attach your panel file and we will take a look at it. The routines that track when a specific firmware feature is used were written to properly remove references when buttons and/or pages are deleted. Perhaps you have found an unexpected loophole. Thanks.
    Rob
    Thanks for the replay! I tried uploading the file but it is to large 900k zippped, email me your email address at gary@gslogic.info and I'lll send it.
