Sony PFM42X1
Can someone post some example command set of this device? I need an example of a control command, the query commands in the documentation work but they have no example of a command. Should look something like: Power on: $8C, $00, $00, $01, $01 - does not work.
I think you need to send command 3 before sending command 2. I noticed that you were missing the checksum.
The document didn't mention anything about a checksum. The more I work in AV the more crapy documentation I come across.
Sony commands tend to be similar between different devices and the code you posted at first looked close to the commands for the Bravia XBR5. Yep no check sum in your docs.
You had... Power on: $8C, $00, $00, $01, $01
I wonder if you have to send the Execute Judge command $89, $00, $00, $FF, $FF.
