G4 Panel issue
I recently had a NXD-700Vi returned from repair only to find it not working. The unit wasn't booting and only displayed a white screen. My first thought was a bad CF, so I replaced it with a CF from another panel I had here. Still the same issue. =( After a close inspection of the daughter board I saw the connector was slightly raised on 1 side. I reseated the board and everything worked. What I noticed is the daughter board has 3 screws that hold it in place but none of these screws are near the only connector on the board. I have called tech support and advised them of the issue and have asked if it would be possible to add a clamp to hold the daughter board in place. Just a heads up for any programmers that are also techs.
