Could not find file????
Thanks in advance for any help.....Im trying to add a Netlinx mudule for a PLB-Amp8. I defined the module as per the instructions: DEFINE_MODULE 'AMP8-Mod' mdlAmp8(vdvAmp8,dvAmp8)
I added it just above the define start area..(thats where I always define my modules) try to compile and get this.
ERROR: C:\Documents and Settings\pattons\My Documents\AMX\Projects\Patton Home\PattonHome.tko(0): L20206: File [AMP8-Mod.tko] could not be found
just wondering if anybody has seen this before...hopefully its just something Im overlooking.
  • SCOTTYPSCOTTYP Posts: 32
    Figured it out
    IT WASNT ME...Apparently there was a typo in the name of the file in the attached data sheet for the module.The Define module they say to copy over has a dash in the wrong place....It only took me three hours to figure it out. (<
    sarcastic remark)
  • JDaggittJDaggitt Posts: 15
    How did you solve it.
    Scotty --
    I noticed that the documentation for the PLB-AMP8 says:
    Define_Module 'AMP8-Mod' Module_Name (v_device, real_device)
    Did you just code it as:
    Define_Module 'AMP-8Mod' Module_Name (v_device, real_device)
    Note that the 8 is shifted from in front of the dash to behind the dash.
    Any help would be appreciated.
    -- Jack Daggitt
