Denon 3800DB not responding to serial
adysadys Posts: 395
Hi all
Has anyone worked with this model?
Its a Blue Ray DVD.
Can't make it work via serial, even that the protocol is the standard Denon protocol.
The AMX driver is old (and also not working)
to turn it on:
$02,$20,$00,$00,$00,$00,$00,$03,$32,$33
Tried with "Control a Device"
Tired with Console..
The device is not responding.
Any Ideas?
Adys.
  • KrobarKrobar Posts: 32
    Try disabling the Auto Off / Power Save feature (On by default). It needs to be disabled for RS232 to work on this model.
  • adysadys Posts: 395
    Thanks a lot!
    That solved the problem.
    Is this is documented issue?
    The serial protocol don't say nothing about it
    Thanks again, you saved me a lot of time
    Adys.
    Documented or not, it's getting to be standard procedure, especially with Marantz products (and in this case Denon = Marantz, it's the same chassis).
