Vst
Hi,
I would like to propose VST to air cond which I have never used.
Would anyone please let me know if the connectors of Equipment Terminal are 24VAC Relay? Is relay triggered by the temperature sensor inside?
Connector of Equipment Terminal: RC, RH, R.V.Cool(O), RV Heat(B), G, HUM/W1, DEH/Y1, W2, Y2.
Charles
  • ViewStat
    Charles,
    If I understand your question correctly, yes, the ViewStat is compatible with and designed for the control of standard 24V HVAC equipment. The ViewStat has an optional power supply which is generally (highly) recommended for use to power the thermostat separate from 24V provided by the HVAC system (the thermostat really needs a clean power source). The thermostat will energize the appropriate heat/cool relays based on the configuration of the thermostat (type of HVAC equipment) and based on the sensor configuration. The ViewStat supports temperature sensing using the built-in sensor or through the use of external temperature sensors.
    Check out the following for more information:
    http://www.amx.com/techdocs/93-0944.pdf
    Hope this helps,
    Reese
