Pop ups react different from TP-WEB
Thomas Hayes
                    Hi Everyone
I have an odd problem that I can't figure out. When I active a pop up page on my panel it works fine but when I try the same button from the web-panel I loose the top of my pop up. What I have is a pop up overtop of a pop up. The top section shows what monitor is being controlled and the bottom the actual controls. By selection the monitor the bottom changes from the controls for one monitor to the other.
I don't have an answer to your exact problem though, I haven't run into that one. I'm not sure if it's at all helpful, but as a rule of thumb, I dumb down web panels as much as I can to minimize such idiosyncrasies, and to minimize display response latency. Perhaps in your case it would just be easier to do a full page flip, duplicating the controls that are common , and replacing the differing ones rather than using a popup.
Thanks for the info. I knew about the fonts issue but this is the first time I've seen this problem. I thought it was something I was doing wrong. I ended up modifing the pop up pages so that the adjustments and monitor controlled are all on the same page and all I end up doing is pop up page flips depending what monitor the client wants to control. I just found a few more glitches that I am trying to fix with the web pages. I suspect the problem lies with the conversion to HTML. It's to bad these glitches exist because the web-pages are very important to my help desk staff(saves me a lot of walking too) when a client doesn't know where the 3 button from the left on the top row is.
But anyway, it's not a limit of technology, it's adherence to a naming standard.
So, considering how few bugs have come up, I'd say it's not that bad..
Kevin D.
