[Ir]Ad Notam
Hi to all,
is my first post in this forum and I hope to write in the right section.
I need to find the discrete ir codes to switch on or off an Ad Notam Lcd monitor.
Thanks for the support.
  • whitewhite Posts: 7
    This my simple module for mirrow tv
    MODULE_NAME='AdNotam_COMM'(dev vdvTV,dev dvTV)
    (* FILE_LAST_MODIFIED_ON: 04/04/2006 AT: 11:33:16 *)
    (* System Type : NetLinx *)
    (* REV HISTORY: *)
    $History: $
    #INCLUDE 'SNAPI'
    (* CONSTANT DEFINITIONS GO BELOW *)
    DEFINE_CONSTANT
    CHAR PowerOFF[] = {$bb,$00,$1f,$01,$01,$21}
    CHAR PowerON[] = {$bb,$00,$1f,$01,$00,$20}
    CHAR CompVideo[] = {$bb,$00,$20,$02,$00,$0d,$1f}
    (* VARIABLE DEFINITIONS GO BELOW *)
    DEFINE_VARIABLE
    volatile char flagTV_AD_Notan_On //0 - off,1-on
    (* STARTUP CODE GOES BELOW *)
    DEFINE_START
    wait 10
    send_command dvTV, 'SET BAUD 57600,N,8,1'
    DEFINE_EVENT
    BUTTON_EVENT[vdvTV,POWER]
    PUSH:
    IF( !flagTV_AD_Notan_On)
    SEND_STRING dvTV,PowerON
    ON[vdvTV,LAMP_POWER_FB]
    ELSE
    SEND_STRING dvTV,PowerOFF
    OFF[vdvTV,LAMP_POWER_FB]
    BUTTON_EVENT[dvTV,SOURCE_TV1]
    PUSH:
    SEND_STRING dvTV,CompVideo
