RTI and AMX integration?
                    Hello all,
Please let me start by saying, I am new to AMX. I have been thru designer / installer and programmer 1 and for our first project we hired an independant programmer. I am now working on my first system (our showroom, so I have time to screw things up and learn from them). I feel confident that I can make everything work using an inwall touchpanel for our showroom theater and whole house audio (setup in zones for the offices with MET6N and a 500i for the boss).
What I'm looking to do also and this is were I really need the help is intergrating an RTI T2c with an RP6 into the system to allow handheld control of the theater. If someone would be willing to give me a tutorial on how this is done that would be great.
Thanks in advance.
Toby
Thanks in advance.
Toby
The way we did it, is by using the XP8, I used the Remote in RF mode. In conjuction with the MIO-IRRX. I programmed the remote to pulse AMX IR Channels. Then use the XP8 to control which IR port it goes out. Then programed in the AMX using button_events.
The other option is to use the AXlink AXB-RF but this restricts you to 255 channels.
Thanks Toby
ie as a start send a simple number - say 678, then in your data_event string handler you can capture this string and try to work with it. i.e
data_event[dvRTI_CM232] { Online: { //port config here } String: { send_string 0, "'String from RTI= ',data.text" } }Then watch in diagnostics.There are tons of posts on here about parsing, but also look up LEFT_STRING, REMOVE_STRING & MID_STRING for starters in Netlinx help. Also look at data.text and CREATE_BUFFER. Once you understand how the string is received by AMX, you can then manipulate this and have it work for you.
Have a try and if you get stuck come back and post your code.
couple of fragments from our setup
this is what we use in the online event
send_command dvRTI, "'SET BAUD 9600,N,8,1'" - we've always used this when combining RTI RP6s and AMX Masters and it's fine
this is the beginnings of what we use to get the data out to do something sensible with it
WHILE (FIND_STRING(RTI_BUFFER,"13",1)) // Parsing data against the pattern below and looking for strings ending with a CR (Decimal 13)
// <<RTI,RO:nnn,DV:nnn,CO:nnn>> (string format for the RTI commands)
Agree with Jim, have a play, look at the string manipulation commands and see what you can come up with.
a:b<CR>
Where a is the room number or remote number; b is the code number (i.e. 1 - play, 2 - stop, 3 - pause, etc.) and it's ended with a carriage return so it's easier to parse.
I keep all the code numbers the same as the panel's code numbers so it's easy to integrate and it also makes it portable since my channel codes are the same from job to job.
For instance CH would go from 1-1000. If I have 10 devices being controlled then channels 1-100 would be device 1, 101-200 would be device 2, 201-300 would be device 3, etc... If we have 20 devices then the channel groups would be smaller, 1-50 is device 1, 51-100 is device 2, etc...
In code it would look like this (after you parse out the R and the CH):
DEFINE_CONSTANT INTEGER kChannelGroupSize = 50 //Number of channels we're using per device DEFINE_FUNCTION fnInitiateCommand(INTEGER nRemID, INTEGER nCH) { nDeviceID = ((nCH-1)/kChannelGroupSize)+1 nCH = ((nCH-1)%kChannelGroupSize)+1 PULSE[dvDeviceArray[nDeviceID],nCH] //Or PULSE[dvDeviceArray[nDeviceID],nChannelArray[nDeviceID][nCH]] if the channel #s don't line up with the IR File }Or if you need more than just a 'PULSE' you can use this instead:IF(nRemID == 1) { IF(nDeviceID == 1) { SWITCH(nCH) { CASE 1: { //do stuff here } CASE 2: { //do stuff here } CASE 3: { //do stuff here } . . . } } }This code gives me a lot of flexibility in what I can do.
--John
Toby
You shouldn't need a remote number, the device ID tells you which device the string is from no?
In one of our typical setups we might have 3-4 RTI remotes each of which might be controlling one or more satellite boxes, one or more tuners, one or more Kaleidescape players, lights etc. And they might be doing that in any one of 10-20 rooms.
All the master sees is the communication from the RTI RP6 on one serial port. So dvRTI = 5001:2:1
Information about device, room and command has to be in the string coming from the RTI
Ah, I thought you were using one RP6 per remote.
Would that mean that you couldn't have a wandering remote with which you can control more than one zone?
http://www.brilliantliving.co.uk/option,com_docman/task,cat_view/gid,90/Itemid,70/
I ran the program but couldn't find a way to switch rooms. I always liked RTI remotes though, and wish the company I work for now would sell them. The only fly in the ointment I found with them when using RF was that if one remote was holding down a button like volume up, and then someone else was also holding a button down, when the first person released the button, it wouldn't release until the second remote released their button.
we've never seen that limitation in live projects, think we've got 8 going in our largest AMX/RTI implementation - guess it's there though, just don't see it in day to day usage
Ref the windows executable. One of them is just a bog standard cinema demo, the other is a whole house implementation. In this instance the home button should take you back up the hieracrchy
