Home AMX Technical Discussion
Cannot upload file to 5200i
Hi, I've upgraded my TPDesign to the latest version and now get an error message when trying to upload tp files. The initial message is that I need to upgrade my system graphics to v6 from v4 - when I select ok it connects to the touchpanel, and then returns a timeout error...
Error Performing Get Panel Manifest - Timeout Error
Anybody else experienced this?
  • Happened a few times and overcame it by uploading with NS.
  • hodeyphodeyp Posts: 104
    thanks - that seems to have solved the problem!
  • hodeyp wrote: »
    TPDesign tries to update the steup pages here. In some rare cases, you may get the panel manifest timeout, You may try "remove user pages" from the protected setup page, and then try again to download your tp file.
    In case of a 5200, please chack the firmware. v2.60.64 is highly recommended.
    Ihave been working on anew install with lots of new panels. One annoying feature is that tpd4 will continue to occasionally install new system graphics on panels that are clearly up to date. This is annoying because this can add 10 minutes to the download when doing so remotely. I seem to remember being able to bypass this before. Now, we don't seem to have a choice.
    ericmedley wrote: »
    They most likely added an image or two, then set the version flag higher to insure the new graphics get loaded. Too bad they don't seem to itemize system graphics on the manifest; it's all or nothing.
