Which firmware file for duet module
Sorry this is probably a bit of a dumb question.
If I am using the ReQuest Duet module on a NI3000 I presume you have to use the following firmware file
NI Series (X000) Duet Master Firmware v3.41.422
And the following firmware file will not work
NI Series (X000) Master Firmware v2.32.148
I can't seem to find a definate answer for this
Thanks in advance
  • Oceanic wrote: »
    Thanks in advance
    It's simply that a Master Firmware < v3 will not support Duet at all.
  • OceanicOceanic Posts: 5
    Thanks Marc
