Device Mapping problem
In NS3, Device Mapping does not work properly.
Any devices you define will not be available in the Device Mapping dialog. This means if you create a new workspace, define a bunch of devices, then open Device Mapping, there will be no devices to choose from....
It is a reported bug. Workaround is to close Studio and reopen. The Device Mappings dialog is only populated upon start up of Studio.
  • BigsquatchBigsquatch Posts: 216
    Did you try doing a save all before trying to map?
    In NS2 you get the same thing unless you save all.
  • ColzieColzie Posts: 470
    No difference after Save All.
    Tech support was pretty clear (after they found a previous case with notes) that Device Mappings will only show devices present when Studio is opened.
    Colzie wrote: »
    This is sad on my part...
    I knew this during beta testing. It was one of those things I noted but didn't report because there were other bigger fish to fry.
    It's just one of those things I kinda worked around.
  • I found this also. And also employed the same workaround. If your devices are connected and online when you open studio, is no problem.
  • PhreaKPhreaK Posts: 966
    Ditto here
