Can you have an array of functions?
(i.e Function Subroutines, defined in DEFINE_FUNCTION)
And then refer to them as per other arrays, e.g. within a button event thus:
DEFINE_VARIABLE
dfMyArrayOfFunkyFunctions[] = { ( fnMyfunction() ), ( fnMyFunction2() ) }
DEFINE_FUNCTION fnMyFunction()
// do awesome stuff
DEFINE_FUNCTION fnMyFunction2()
// do more awesome stuff
BUTTON_EVENT [ dvMyTP, dcMyButtons ]
STACK_VAR nBtnIdx
nBtnIdx = GET_LAST (dcMyButtons)
// dofunction ( dfMyArrayOfFunkyFunctions [button.input.channel] )
or similar.
Could you create something with structures maybe? Or maybe the keyword simply doesn"t exist (e.g. a keyword like DO_FUNCTION, or something)?
Purpose: to simplify code, make it more modular, avoiding multiple SWITCH...CASEs or SELECT...ACTIVEs.
DEFINE_VARIABLE
// do awesome stuff
STACK_VAR nBtnIdx
or similar.
There is a way you could do what I think you are after tho. You could write one more function that calls the funky functions.
DEFINE_FUNCTION fnPickAFunction(integer nFunctionRequested){ switch(nFunctionRequested){ case 1: fnMyFunction1(); case 2: fnMyFunction2(); case 3: fnMyFunction3(); default: fnMyFunctionRandom(); } } DEFINE_FUNCTION fnMyFunctionRandom(){ stack_var integer nFunctionRequested; nFunctionRequested = RANDOM_NUMBER(3) +1; switch(nFunctionRequested){ case 1: fnMyFunction1(); case 2: fnMyFunction2(); case 3: fnMyFunction3(); default: fnMyFunctionRandom(); } } DEFINE_EVENT button_event[dvTP,nMyButtons]{ PUSH:{ fnPickAFunction(button.input.channel); } }I'm not sure where this might be applicable in a job, but it should work if I am interpreting your requirements properly. (I through the random function in for fun
it's for a job with two rooms, 2x MET KPs, 14 buttons on each, 1 in each room, same room layout, same same everting, off 1x NI3100, 1 vol box axb-vol3.
Just wanted to rinse and repeat, reallly! If they added more rooms i could connect them to the same master wouldn't have to change code much, just add one more device to each array (extra screen, extra proj and extra kp, extra vol box) until i ran out of ports or the maths becomes too hard for scaling (for referencing the elements in the array using (button.input.device.number - xx ) and (b.i.c - xx)). I could even declare those devices in the code right off the bat then not have to change anything when/if the time comes to add stuff (providing the added kit is the same).
anyhooze, too drunk watching murray v roddick!
cheers
FYI, here's what I've come up with...
PROGRAM_NAME='Generic_Code' DEFINE_DEVICE dvDISPLAY_01 = 5001:1:0 dvDISPLAY_2 = 5001:2:0 dvDISPLAY_03 = 5001:3:0 dvDISPLAY_04 = 5001:4:0 dvRELAYS = 5001:8:0 //1,2,3,4 UP ROOMS 1,2,3,4 :-: 5,6,7,8 DOWNS ROOMS 1,2,3,4 dvKP_01 = 128:1:0 dvKP_02 = 129:1:0 dvKP_03 = 130:1:0 dvKP_04 = 131:1:0 dvPGVOL_01 = 170:1:0 // rooms 1 &2 dvPGVOL_02 = 171:1:0 // rooms 3 &4 (***********************************************************) (* CONSTANT DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_CONSTANT INTEGER nON = 1 INTEGER nOFF = 0 INTEGER nSCREEN_UP = 1 INTEGER nSCREEN_DOWN = 0 INTEGER srcNONE = 0 INTEGER srcVID = 1 INTEGER srcSVID = 2 INTEGER srcYUV = 3 INTEGER srcPC = 4 INTEGER srcPC2 = 5 INTEGER srcHDMI = 6 (***********************************************************) (* DATA TYPE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_TYPE (***********************************************************) (* VARIABLE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_VARIABLE INTEGER nPROJ_POWER INTEGER nSOURCE INTEGER nSCREEN DEV dvDISPLAYS[] = { dvDISPLAY_01, dvDISPLAY_2, dvDISPLAY_03, dvDISPLAY_04 } DEV dvKEYPADS[] = { dvKP_01, dvKP_02, dvKP_03, dvKP_04 } DEV dvVOLBOXES[]= { dvPGVOL_01, dvPGVOL_01, dvPGVOL_02, dvPGVOL_02 } INTEGER dcKP_BUTTONS[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14 } INTEGER nBUTTON_PUSHED INTEGER nDEVICE_THAT_BUTTON_WAS_PUSHED_ON INTEGER nPUSH DEFINE_FUNCTION fnPickAFunction(integer nFunctionRequested) { switch(nFunctionRequested) { case 1: fnMyFunction1(); case 2: fnMyFunction2(); case 3: fnMyFunction3(); case 4: fnMyFunction4(); case 5: fnMyFunction5(); case 6: fnMyFunction6(); case 7: fnMyFunction7(); case 8: fnMyFunction8(); case 9: fnMyFunction9(); case 10: fnMyFunction10(); case 11: fnMyFunction11(); case 12: fnMyFunction12(); case 13: fnMyFunction13(); case 14: fnMyFunction14(); } } DEFINE_FUNCTION fnMyFunction1() { SEND_STRING dvDISPLAYS[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],"'STRING_01'" // ON PULSE [dvRELAYS,(nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127)] //SCREEN DOWN nPROJ_POWER = 1 } DEFINE_FUNCTION fnMyFunction2() { SEND_STRING dvDISPLAYS[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],"'STRING_02'" // OFF PULSE [dvRELAYS,(nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-123)] //SCREEN UP nSOURCE = srcNONE nPROJ_POWER = 0 } DEFINE_FUNCTION fnMyFunction3() { SEND_STRING dvDISPLAYS[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],"'STRING_03'" // SELECT VID 1 nSOURCE = srcVID } DEFINE_FUNCTION fnMyFunction4() { SEND_STRING dvDISPLAYS[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],"'STRING_04'" // SELECT SVID nSOURCE = srcSVID } DEFINE_FUNCTION fnMyFunction5() { SEND_STRING dvDISPLAYS[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],"'STRING_05'" // SELECT YUV nSOURCE = srcYUV } DEFINE_FUNCTION fnMyFunction6() { SEND_STRING dvDISPLAYS[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],"'STRING_06'" // SELECT PC nSOURCE = srcPC } DEFINE_FUNCTION fnMyFunction7() { SEND_STRING dvDISPLAYS[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],"'STRING_07'" // SELECT PC2 nSOURCE = srcPC2 } DEFINE_FUNCTION fnMyFunction8() { SEND_STRING dvDISPLAYS[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],"'STRING_07'" // SELECT HDMI nSOURCE = srcHDMI } DEFINE_FUNCTION fnMyFunction9() { // YOU KNOW, LIKE, DO STUFF } DEFINE_FUNCTION fnMyFunction10() { // YOU KNOW, LIKE, DO STUFF } DEFINE_FUNCTION fnMyFunction11() { // YOU KNOW, LIKE, DO STUFF } DEFINE_FUNCTION fnMyFunction12() { // YOU KNOW, LIKE, DO STUFF } DEFINE_FUNCTION fnMyFunction13() // should ramp up at defined level until nPUSH = 0, which it is when RELEASE happens { IF(nPUSH = 1) { IF(nSOURCE<>srcPC2) { IF(nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 128 || nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 130) { ON[dvVOLBOXES[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],4] } ELSE IF(nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 129 || nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 131) { ON [dvVOLBOXES[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],7] } } } IF(nPUSH = 0) { IF(nSOURCE<>srcPC2) { IF(nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 128 || nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 130) { OFF [dvVOLBOXES[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],4] } ELSE IF(nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 129 || nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 131) { OFF [dvVOLBOXES[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],7] } } } } DEFINE_FUNCTION fnMyFunction14() // same saem, but ramping down { IF(nPUSH = 1) { IF(nSOURCE<>srcPC2) { IF(nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 128 || nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 130) { ON[dvVOLBOXES[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],5] } ELSE IF(nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 129 || nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 131) { ON [dvVOLBOXES[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],8] } } } IF(nPUSH = 0) { IF(nSOURCE<>srcPC2) { IF(nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 128 || nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 130) { OFF [dvVOLBOXES[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],5] } ELSE IF(nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 129 || nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = 131) { OFF [dvVOLBOXES[nDEVICE_THAT_BUTTON_WAS_PUSHED_ON-127],8] } } } } DEFINE_EVENT button_event[dvKEYPADS,dcKP_BUTTONS] { PUSH: { nPUSH = 1 nBUTTON_PUSHED = button.input.channel nDEVICE_THAT_BUTTON_WAS_PUSHED_ON = button.input.device.number fnPickAFunction(button.input.channel); } RELEASE: { nPUSH = 0 } }
