Functions and Multi-Dimensional Arrays
Is it possible to return a multidimensional array from a function? Currently I get the following runtime error:
GetString - Error 1 Tk=0x0000 CopyString (Reference) - Error 2 S=0x0000 D=0x1033
Sure. For example:
Which is run as: where
DEFINE_FUNCTION CHAR[][] fnTest ()
I'd compile except I got a strange error that pops up saying: "This special version of the NetLinx Compiler has now expired (Monday, June 01, 2009). Please contact AMX for further information." :eek:
Clearly not accurate, but that'd be a no on returning multidimensional arrays. Just pass a variable as a parameter (ie. by reference) and put the return value in that variable.
That won't compile. If you are returning an array it has to be bounded.
I've contacted AMX here in australia to see if it's possible. They've had a quick play and weren't able to give a definative answer as to weather it can, or should, work, however they're getting in touch with their american couterparts for some info. When I hear back I'll post the results.
Instead of using a RETURN to handle the structure/array, just create another variable to hold the content you want to copy. I do it all the time with very large multi-dimensional structures and arrays. You might have to rethink some of your code design, but it will works.
@Auser manipulating variables passed as parameters goes against all rules of nice coding. It will work but I try to keep everything as logical and standardised as possible in all my code as it tends to prevent a lot of issues in the future.
I am reluctant to use external variables. but I think I will have no way out. I need a function that returns a DEV.
I must've missed this one back in the day. I'm not saying you're wrong, but if you've only got coconuts to work with, you can only build stuff out of coconuts. Think of the array variable you're passing in as a pointer to itself if it'll make you feel better :P
I know there are other ways to do it, but most of the ways I've thought of result in code which is more obfuscated and prone to errors and maintenance issues.
Another bug with passing a multidimensional array is that array/string_max_length (and possibly array/string_length too, can't remember) return 0 instead of the proper value when used in the function you passed the array to (at least with unbounded arrays). Compiler bugs suck.
The hard part is creating a logical structure and change everything because of it.
I had to work a little more so that everything remains flexible and dynamic as I had thought.
At the end are going alright.
If it were to stay in the module I would have no problem ccreating a global struct or even changing values by reference. I've never been taught the "correct" rules and never was very good at following rules anyway.
Instead of sending it out as a string I could just as easily reloaded the initial struct or new structure with the returned value using the string_to_var which is what I do in the main code. It just isn't worth it IMHO if you don't have to transport it out of a module.
We seem to be in violent agreement on this one. I never suggested he was wrong (note the "I'm not saying you're wrong" bit in the post you replied to) and never said it was a nice way to do things in other languages, I was just miffed that I gave the answer to the question posed in the OP citing a literary reference and a suggested solution and the original poster suggested that he was above doing such things but didn't offer an alternate, more elegant solution.
As I said,
Ultimately, there are limitations in the language and you have to work within those limitations.
FWIW, I have never come across this.
So given the comments to the effect that it is universally bad practice to return results from a function in variables passed to the function by reference (naughty AMX engineers and their REMOVE_STRING function), here's a challenge for everyone. I'm always happy to learn new things and look forward to seeing what you come up with.
The rules are simple:
- Create a function that adds a string to a list of strings stored in a 2D char array
- The function must be able to deal with arrays of any realistic size
- Comments should be limited to Netlinx, we're not dealing with Duet (or other languages) here
- The function may return it's result in any way
- The function must be at least as logical/elegant/efficient as the following:
Vining has already mentioned a method (ie. using var_to_string/string_to_var) which I'll have to discount based on grounds of efficiency in this particular scenario. (There's nothing wrong with the method in other places - I've been known to use var_to_xml/xml_to_var to pass complex data sets between disjoint processing systems (across module/machine boundaries) on rare occasions..
Apologies if it came across like that - upon reading it back it does sound rather douchebag-esque. I didn't offer an alternative because I didn't have one, hence the post. I was just trying to keep the discussion going.
Where there is no way around it I've been using the same technique you suggested, and just ensuring that the function name, parameter names and comments make it clear that the variable passed will be manipulated.
