Current Array Status
Hi,
Hope someone can help me here, or at least tell me what I am trying to do is not possible. I've scoured the forum, but found nothing to help.
I am using an array to determine the current open/closed status of 6 room partitions:
INTEGER PART_ARRAY[6] //1 or 0 to state open or closed
INTEGER PANEL_ARRAY[5] //1 or 0 to state which panels in use
All I want to do is read the current status so I can set which slave panels are in use. I assumed the following to work fine, but unfortunately does not:
IF (PART_ARRAY[] = {0,1,1,1,1,1})
MASTER_ARRAY[] = {1,0,1,1,1}
Can anyone offer any solution to stop my hair falling out.
Much appreciated,
    I'm not sure what result you're looking for but one thing is you don't need the []s on the arrays in the IF statement. That implies that you intend to eval one particular cell of the array. [3] would mean the value of cell 3. A blank might imply cell zero. (I think???). Cell zero does not exist in Netlix. It does in other languages like C or Java.
    My guess is that if you run 'MSG ON ALL' in terminal you'll see a 'zero index' error when the line runs. Hope that help
    e
  • SmallSmall Posts: 9
    What I'm trying to do really is save code/time. The second array needs to change according to the contents of the first array, such like:
    IF ((!PART_ARRAY[1])&(PART_ARRAY[2])&(PART_ARRAY[3])&(PART_ARRAY[4])&(PART_ARRAY[5])&(PART_ARRAY[6]))
    MASTER_ARRAY[1]=1
    MASTER_ARRAY[2]=0
    MASTER_ARRAY[3]=1
    MASTER_ARRAY[4]=1
    MASTER_ARRAY[5]=1
    I assumed would work fine as:
    IF(PART_ARRAY[]={0,1,1,1,1,1}) MASTER_ARRAY[]={1,0,1,1,1}
    or:
    IF(PART_ARRAY={0,1,1,1,1,1}) MASTER_ARRAY={1,0,1,1,1}
    But unfortunately does not.
    If it can't be done, I'll just have to do it the long way :(
  • JohnMichnrJohnMichnr Posts: 279
    I would have thought the compiler would barf at the curly braces in the middle of the if statement.
    But now that you mention it - I am not sure that I know how to setup that statement with out doing multiple ifs and &&.
    have you tried
    if(PART_ARRAY = (1,1,1,0,0)) no square brackets no curley brakets? (for the reason that Eric mentioned previously)
    It needs quotes when done like that, and definitely leave off the empty [], you only need those when you declare it, or if you are referencing a single element. Think of it like a string.
    if(PART_ARRAY = "1,1,1,0,0"), etc.
    If this is something that you need to use multiple times in your code, you could just write a function to handle it.
    Here is a quick attempt at a function:
    define_function integer fnCompareMyArray(integer ArrayIn[],integer CompareToThisArray[]){
    	stack_var integer x;
    	if(max_length_array(CompareToThisArray) > max_length_array(ArrayIn))
    		return 0;
    	for(x=max_length_array(CompareToThisArray);x;x--){
    		if(ArrayIn[x] <> CompareToThisArray[x])
    			return 0;
    	return 1;
    button_event[dvTp,202]{
    	push:{
    		local_var integer nMainArray[6];
    		local_var integer nTestArray[6];
    		local_var integer nTestArray2[5];
    		on[nMainArray[1]];
    		off[nMainArray[2]];
    		on[nMainArray[3]];
    		on[nMainArray[4]];
    		off[nMainArray[5]];
    		on[nMainArray[6]];
    		on[nTestArray[1]];
    		off[nTestArray[2]];
    		on[nTestArray[3]];
    		on[nTestArray[4]];
    		off[nTestArray[5]];
    		on[nTestArray[6]];
    		send_string 0,"'Function returned: ',itoa(fnCompareMyArray(nMainArray,nTestArray))";
    		off[nTestArray[6]];
    		on[nTestArray2[1]];
    		off[nTestArray2[2]];
    		on[nTestArray2[3]];
    		on[nTestArray2[4]];
    		off[nTestArray2[5]];
    		send_string 0,"'Function returned: ',itoa(fnCompareMyArray(nMainArray,nTestArray2))";
    		off[nTestArray2[4]];
    But, it seems that Dave's code will do what you want :)
    DHawthorne wrote: »
    Quality, thanks for that. That sorts out the first part, but unfortunately doesn't work when trying to set the second arrays contents, i.e:
    IF (PART_ARRAY = "1,1,1,0,0") // WORKS FINE
    MASTER_ARRAY="0,0,1,0,1" // Does not work. Sees as string.
    MASTER_ARRAY={0,0,1,0,1} // Also, does not work.
    MASTER_ARRAY=(0,0,1,0,1) // Also, does not work.
    Any ideas?
  • HedbergHedberg Posts: 671
    Have you tried using CHAR variable type as opposed to INTEGER type? Depending on what you do, you may experience some compiler warnings about type, but a type_cast should resolve them.
    A CHAR variable is actually an 8-bit integer and you can use CHAR variables as flags and such so long as you pay attention. If you do, then such things as
    will work just fine.
    Never thought of that, I'll give it a shot.
    Cheers,
    I guess I'll make the suggestion. If you are only dealing with 6 zones, you could go bitwise. This would let you do some things like:
    define_constant
    zone1 = $01
    zone2 = $02
    zone3 = $04
    zone4 = $08
    zone5 = $10
    zone6 = $20
    zone7 = $40
    zone8 = $80
    define_variable
    integer PART_STATUS
    integer MASTER_STATUS
    if(PART_STATUS & (zone1 + zone3 + zone5))
        MASTER_STATUS  = zone 2 + zone5;
    if(PART_STATUS BAND (zone1 + zone3 + zone5)) //same thing using keyword instead of operator.
    This also allows you to easily see if any zone is on (if(PART_STATUS) send_string 0,"'Atleast one zone is ON'")
