Heads Up - Weather.com XOAP
Not sure if anyone's noticed any issues when using Weather.com's XML feed, but I noticed today that it wasn't working - and it'll affect all of my clients.
Anyway . . . here's a thread I found on another board that seems to explain quite a bit.
http://www.rainmeter.net/forum/viewtopic.php?f=4&t=588
A few highlights from the thread . . .
1) the XOAP XML Page will be in and out over the next 48 to 72 hours as the folks at Weather.com update their service.
2) Apparently there call board has been lit-up all day. The folks at weather.com are just now realizing the extent of the abuse that their XML feed has received and is considering a shutdown of the current XML OAP feed that we currently use.
3) The folks at weather.com have adopted andi]sic[/i identification system for their future feeds.
4) The current URL that we use looks something like the following:
http://xoap.weather.com/weather/local/8 ... =f&dayf=10
The new standard will look like the following:
http://xoap.weather.com/weather/local/3 ... =xoap&par=[PartnerID]&key=[LicenseKey]
where [PartnerID] is your unique Partner ID and [LicenseKey] is your unique License Key.
Anyway . . . be prepared to register for the service or change providers.
I have the dynamic image module running in my home system and that stopped working on Sunday. However, the non-dynamic module, the one that has the weather images loaded into the panel is still working on my office. Looks like that they stopped the dynamic images feed, but still have the text only working. I just thought that you would like to know that. Too bad they will block the XML data, your module still is the best weather module I've seen.
Ricardo
You're running my module? I didn't know it was out there (not that I care.) But surely, there are better ones.
I am sorry, you're right. I am not using your module. I was using AMXJeff's module. Somehow, I got your name mixed up with AMXJeff. Anyways, his module also uses weather.com XML feed, which also stopped working. His module has 2 versions: Dynamic Images and Non-Dynamic. The dynamic image module, which uses the weather.com images stopped working, but the non-dynamic module, which uses only text, still works. Again, I am sorry for the confusion.
Ricardo
At one time the XML feed from rssweather actually read something along the lines of "feed can only be accessed once an hour" if you attempted it from the same IP.
oh... different source... this is from www.weather.com and is not an RSS feed...
Hey Ricardo...
By the way the Dynamic Images seem to work still too..
