Issues with ClearOne XAP Module
There appears to be a small bug with the ClearOne XAP module (v1.0.3) found on the AMX site. It doesn't properly interpret the PROPERTY-NetworkConfig command. However, if you specify device types as integers (rather than converting them to their ascii equivalents it will properly read string returned from a network of XAP's.
Additionally it does not properly form the headers of command it sends to the physical device. However, it is possible to create a virtual device to act as a proxy and re-write outgoing strings.
PROGRAM_NAME='XAP Example'
DEFINE_DEVICE
dvDSP = 5001:1:0 // Clearone XAP network
vdvDSP = 41001:1:0 // Duet device for XAP module comms
vdvXAPProxy = 41002:1:0 // Proxy device for command translation. A Duet
// has been used as they don't echo back
// string, thus preventing an infinite loop.
DEFINE_CONSTANT
INTEGER DSP_TYPE_XAP800 = 5 // Device types
INTEGER DSP_TYPE_XAPTH2 = 6
INTEGER DSP_TYPE_XAP400 = 7
DEFINE_COMBINE
(vdvXAPProxy, dvDSP) // These devices must be combined to
// allow returned strings to be processed by
// the control module.
* Initializes DSP communication parameters.
* The integer to ascii conversion has been intentionally ommitted to combat
* the bug in the module.
DEFINE_FUNCTION fnDSPInit ()
SEND_COMMAND vdvDSP[1], "'PROPERTY-NetworkConfig,',
DSP_TYPE_XAP400,':0:',
DSP_TYPE_XAP800,':0'"
SEND_COMMAND vdvDSP[1], "'REINIT'"
* Translates an outgoing string from the control module into the correct
* format (see header comment block).
* @param sString the incorrectly formed string to convert
* @return a correctly formed string that the device will understand
DEFINE_FUNCTION CHAR[128] fnDSPTranslateOutgoingString (CHAR sString[])
STACK_VAR INTEGER nDeviceType
nDeviceType = TYPE_CAST(MID_STRING(sString, 2, 1))
IF (nDeviceType == DSP_TYPE_XAP400 ||
nDeviceType == DSP_TYPE_XAP800 ||
nDeviceType == DSP_TYPE_XAPTH2)
RETURN "'#',
ITOA(nDeviceType),
RIGHT_STRING(sString, LENGTH_STRING(sString) - 2)"
} ELSE {
RETURN sString
DEFINE_START
DEFINE_MODULE 'ClearOneXAP_Comm_dr1_0_0' mdlDSP(vdvDSP, vdvXAPProxy)
DEFINE_EVENT
DATA_EVENT[vdvDSP]
ONLINE:
fnDSPInit()
DATA_EVENT[vdvXAPProxy]
STRING:
SEND_STRING dvDSP, fnDSPTranslateOutgoingString(DATA.TEXT)
