Home AMX User Forum AMXForums Archive Threads AMX Applications and Solutions
Extron IPL T PCS4i
I am having trouble getting an Extron IPL T PCS4i to work with my code. This is the first time I have done any controls over IP and I am sure that is the main cause of my problems. Could someone look at the code below and tell me what I am doing wrong?
PROGRAM_NAME='Levels'
DEFINE_DEVICE
#IF_NOT_DEFINED dvPWR_Cntrl_Rack
dvPWR_Cntrl_Rack	=	0:2:0
#END_IF
#IF_NOT_DEFINED dvPWR_Cntrl_WS
dvPWR_Cntrl_WS		=	0:3:0
#END_IF
#IF_NOT_DEFINED dvPWR_Cntrl_Table
dvPWR_Cntrl_Table	=	0:4:0
#END_IF
DEFINE_CONSTANT
NON_VOLATILE INTEGER nIPPort = 23
DEFINE_VARIABLE
IP_ADDRESS_STRUCT ipPWR_CNTRL_Rack
IP_ADDRESS_STRUCT ipPWR_CNTRL_WS
IP_ADDRESS_STRUCT ipPWR_CNTRL_Table
NON_VOLATILE INTEGER nLVL_BTNS[] =
    300,		//
    301,		//
    302,		//
    303,		//
    304,		//
    305,		//lvl 1
    306,		//lvl 2
    307			//lvl 3
DEFINE_START
ipPWR_CNTRL_Rack.IPADDRESS  = '192.168.1.122'
ipPWR_CNTRL_Rack.SUBNETMASK = '255.255.255.0'
ipPWR_CNTRL_Table.IPADDRESS = '192.168.1.123'
ipPWR_CNTRL_Table.SUBNETMASK= '255.255.255.0'
ipPWR_CNTRL_WS.IPADDRESS    = '192.168.1.124'
ipPWR_CNTRL_WS.SUBNETMASK   = '255.255.255.0'
IP_CLIENT_OPEN(dvPWR_Cntrl_Rack.Port,ipPWR_CNTRL_Rack.IPAddress,nIPPort,IP_TCP)
IP_CLIENT_OPEN(dvPWR_Cntrl_Table.Port,ipPWR_CNTRL_Table.IPAddress,nIPPort,IP_TCP)
IP_CLIENT_OPEN(dvPWR_Cntrl_WS.Port,ipPWR_CNTRL_WS.IPAddress,nIPPort,IP_TCP)
DEFINE_EVENT
BUTTON_EVENT [dvTP, nLVL_BTNS]
    PUSH:
	SWITCH(GET_LAST(nLVL_BTNS))
	    CASE 6:	//Set level to 1
		seclevel = 1
		nChange_Flag = 1
	    CASE 7:	//Set level to 2
		seclevel = 2
		nChange_Flag = 1
	    CASE 8:	//Set level to 3
		level = 3
		nChange_Flag = 1
	    DEFAULT:
		level = 0
DEFINE_PROGRAM
IF (nChange_Flag)
    SWITCH (level)
	CASE 1:
	    SEND_STRING dvPWR_Cntrl_Rack, "$1B, '1*1PC', $0D"
	    SEND_STRING dvPWR_Cntrl_Rack, "$1B, '2*0PC', $0D"
	    SEND_STRING dvPWR_Cntrl_Rack, "$1B, '3*0PC', $0D"
	    SEND_STRING dvPWR_Cntrl_Rack, "$1B, '4*0PC', $0D"
	    SEND_STRING dvPWR_Cntrl_WS, "$1B, '1*1PC', $0D"
	    SEND_STRING dvPWR_Cntrl_WS, "$1B, '2*0PC', $0D"
	    SEND_STRING dvPWR_Cntrl_WS, "$1B, '3*0PC', $0D"
	    SEND_STRING dvPWR_Cntrl_WS, "$1B, '4*0PC', $0D"
	    SEND_STRING dvPWR_Cntrl_Table, "$1B, '1*1PC', $0D"
	    SEND_STRING dvPWR_Cntrl_Table, "$1B, '2*0PC', $0D"
	    SEND_STRING dvPWR_Cntrl_Table, "$1B, '3*0PC', $0D"
	    SEND_STRING dvPWR_Cntrl_Table, "$1B, '4*0PC', $0D"
	CASE 2:
	    SEND_STRING dvPWR_Cntrl_Rack, "$1B, '2*1PC', $0D"
	    SEND_STRING dvPWR_Cntrl_WS, "$1B, '2*1PC', $0D"
	    SEND_STRING dvPWR_Cntrl_Table, "$1B, '2*1PC', $0D"
	CASE 3:
	    SEND_STRING dvPWR_Cntrl_Rack, "$1B, '3*1PC', $0D"
	    SEND_STRING dvPWR_Cntrl_WS, "$1B, '3*1PC', $0D"
	    SEND_STRING dvPWR_Cntrl_Table, "$1B, '3*1PC', $0D"
	DEFAULT:
	    SEND_STRING dvPWR_Cntrl_Rack, "$1B, '1*0PC', $0D"
	    SEND_STRING dvPWR_Cntrl_WS, "$1B, '1*0PC', $0D"
	    SEND_STRING dvPWR_Cntrl_Table, "$1B, '1*0PC', $0D"
    nChange_Flag = 0
  • JonathondwJonathondw Posts: 23
    Dwatson8791,
    I can tell you that all of the extron equpiment will close the telnet port after 20seconds of no activaity.
    also you should have a DATA_EVENT for each device so you can monitor each device for when it should fall offline then you can reconnect it.
    DEFINE_CONSTANT
    CONNECTED = 11
    DEFINE_VARIABLE
    integer nTry2Connect
    DEFINE_FUNCTION CloseConnection()
    IP_CLIENT_CLOSE(devDevice.PORT);
    DEFINE_START
    IP_CLIENT_OPEN(devDevice.PORT,192.168.0.0,23,tcp);
    DATA_EVENT[devDevice]
    ONLINE:
    ON[devDevice,CONNECTED]
    CANCEL_WAIT 'make connection'
    OFFLINE:
    OFF[devDevice,CONNECTED]
    WAIT 20 'make connection'
    IF(![devDevice,CONNECTED])
    ONERROR:
    nCONNECTION_ERROR = Data.Number
    IF(nCONNECTION_ERROR = 0)
    ELSE
    IF([devDevice,CONNECTED])
    CloseConnection()
    WAIT 30 'make connection'
    EstablishConnection()
    IF(nCONNECTION_ERROR <> 0 && nCONNECTION_ERROR <> 9)
