Vista Systems: Spyder
Hello,
Has anyone on this forum successfully enabled IP control of a Vista Systems Spyder? This is a PIP (Picture-In-Picture) device that only accepts IP control via UDP. We have been able to open a IP_client session to the device, but, the unit will not respond to the strings that are sent to the unit. We have followed the protocol syntax with no success! Any help would be much appreciated.
Bryce
  • Header
    Looking through the manual for IP control is says it must have 10 digit header before every command being: "'spyder', $00, $00, $00, $00" or "'spyder', $0X, $0X, $0X, $0X". Can't tell which one, the manuals says 0X00. Says no space between the command and the header.
