Precis 0808 - Red flashing status light
Currently at a job using Autopatch Precis 0808, and what was a working system is no longer. Noticed the red LED at the rear of the unit, top right corner is flashing - not a good sign.
Unit's response to any control command is Invalid Selection, and when giving the unit a power cycle, get the following string sent out
IOS intervention forced due to Critical Journal Entry.
Has anyone experienced this, and can it be fixed without having to be sent back to AMX?
At the boot menu where you get the IOS intervention forced due to Critical Journal Entry type the following.
~scr!
This will take you to the splash screen.
Then type:
J
this will prompt you to delete the Journal Entry:
y
to confirm.
Reboot the Autopatch and it should come back up and to normal state and function.
