how to change system time
Hello,
We have a button that shows the current system time, but we would like to offer the possibility to change this time.
So i?d like to know if there is a way to change the system time through NetLinx code.
Thanks!!
Thanks!!
SEND_COMMANDs: "'CLOCK <mm-dd-yyyy> <hh:mm:ss>'" Set the date and time on the Master. The date and time settings are propagated over the local bus. Syntax: SEND_COMMAND <DEV>,"'CLOCK <mm-dd-yy> <hh:mm:ss>'" Variable: mm-dd-yy = Month, day, and year. Month and day have 2 significant digits. Year has 4 significant digits. hh-mm-ss = Hour, minute, and seconds. Each using only 2 significant digits. Example: SEND_COMMAND RS232_1,"'CLOCK 04-12-05 09:45:31'" Sets the Masters date to April 12, 2005, and time to 9:45 am.Salutes!
