how to use Commandfusion software to connect iphone and master(NI-700)
anyone has used the iphone to control your light system ??
i have some problem about the iphone and the master connect setting.
this is diagnostics message.
Line      1 (11:34:21)::  CICSPTCP Rx connection to 192.168.1.8 has been closed locally or by peer
Line      2 (11:34:21)::  Memory Available = 9074680 <37696>
Line      3 (11:34:52)::  CICSPTCP Rx connection to 192.168.1.8 has been closed locally or by peer
Line      4 (11:35:24)::  CICSPTCP Rx connection to 192.168.1.8 has been closed locally or by peer
Line      5 (11:35:55)::  CICSPTCP Rx connection to 192.168.1.8 has been closed locally or by peer
Line      6 (11:36:26)::  CICSPTCP Rx connection to 192.168.1.8 has been closed locally or by
peermaster's ip is 192.168.1.29.i use the 'AMX_Module_REV02' and i don't know how to set the
DEFINE_DEVICE
dvMaster_1 =     0:01:0 (* NETLINX MASTER                               *)
RS232____1 =  5001:01:0 (* 		                    NI-RS232    *)
RS232____2 =  5001:02:0 (* 		                   NI-RS232    *)
dvRelais_1 =  5001:08:0 (*                                  NI-Relais   *)
dvIR_____1 =  5001:09:0 (* 		                    NI-IR       *)
dvIO_____1 =  5001:17:0 (*                                  NI-I/O      *)
dviPhone_1 =     0:02:0 (* iPhone TP Device                 iViever     *)
dvTP__2__1 = 34001:01:0
how can i define a real iphone device
my iphone's ip is 192.168.1.8 and in my iphone setting 'CF iviewer' the 'File URL' is 'http://192.168.1.237:8020 ',but when i use the CF iviewer on my iphone will get a Warning message like"Experiencing intermittent connection loss"
my computer's ip is 192.168.1.237 and use the 'CommanFusion guiDesigner' that i set the 'project properties'--'control system'--'Ip Address' is 192.168.1.29 and 'port' is '1319'.
does anyone have ad ,thanks a lot.
    I don't have this module, so I'm shooting in the dark. But one thing I see in your post that seems odd is that you set the iPhone App's 'control system ip' up using port 1319. That port is used by the Netlinx master and is where AMX communications happen. These include things like uuploading/downloading program files, ir files, etc.. This is also the port used by the IP based touch panels to communicate. Basically, anything AMX talks on this port.
    It would be unusual for a third party setup to try and communicate on this same port. more than likely you need to set the iPone app on port 8020. that's probably where the iPhone module in your program is trying to talk.
    This is just a guess.
    hope this helps.
    e
    I downloaded the module out of curiosity and it says you first need to put the file created by the GuiDesigner on the master before running the module. Do you have that file on the master?
    Is there an app that you load onto the iPhone/Touch?
  • i'm the wgqkaka colleague. you said is right . the iPhone have to download the software named 'CF iviewer' and you must install the another software ''CommanFusion guiDesigner' on your computer.the iPhone can download the interface and code from the 'CommanFusion guiDesigner' on your PC.
    if you have a iPhone ,you can try it yourself .but i saw that crest** have alread used the software like this
    but that is crest** devise itself ,so it has no problem about connect setting. AMX VirtualKeypad is ok ,but it can't be create more button,and the reply is so slow .i don't know what's wrong with it .
    follow is the about commanfusion guidesigner's website .if you have interest you can try it .any ad will appreciate.
    http://www.commandfusion.com/
    and this is the google group
    http://groups.google.com/group/CommandFusion
