panasonic projector - lamp hour query
hi i have a project include to get the lamp hour from the projector. anyone know what is the command for that? i searched on the web and it seems only got the lamp status.
please post as well about the reply string format so i could work on it to get substring. thankyou very much !!!!!!!
Please post the model number of the projector
VOLATILE INTEGER iPROJ_DEBUG NON_VOLATILE CHAR cPROJ_CMDS[60][25] VOLATILE CHAR cPROJ_RX[50] VOLATILE INTEGER iProjectorPower VOLATILE INTEGER iProjectorMute PERSISTENT CHAR cLAMP_HOURS_RX[3][2][6] PERSISTENT cLAMP_MINUTES_RX[3][2][2] INTEGER iLAMP_QUERY_SENT[2][3] INTEGER iPOWER_QUERY_SENT[3] NON_VOLATILE INTEGER iPROJ_WARMING[3] NON_VOLATILE INTEGER iPROJ_COOLING[3] NON_VOLATILE LONG lPROJ_COOL_TIME = 90000 //90 seconds *THISE ARE ALSO SET INT THE TP-POPUP TIMEOUT AND BARGRAPH RANGE HIGH NON_VOLATILE LONG lPROJ_WARM_TIME = 45000 //45 seconds *THISE ARE ALSO SET INT THE TP-POPUP TIMEOUT AND BARGRAPH RANGE HIGH NON_VOLATILE INTEGER iPROJ_COOL_SEC = 90 //90 seconds NON_VOLATILE INTEGER iPROJ_WARM_SEC = 45 //45 seconds NON_VOLATILE LONG lPROJ_POWER_TIME = 5000 //Power Query every 5 Seconds NON_VOLATILE LONG lPROJ_LAMP_TIME = 360000 //Lamp Query every hour LONG lPROJ_TIME_ARRAY[10] NON_VOLATILE INTEGER iPROJ_TIMELINE_TRACKER[]={1,2,3,4,5,6,7,8,9,10,11,12} //3 PROJ, WARM/COOL/POWER/LAMP TIMELINES NON_VOLATILE INTEGER iPROJ_TIMER[3][2] //3 PROJ, WARM/COOL NON_VOLATILE INTEGER iPROJ_INPUT_SEL[3] NON_VOLATILE INTEGER iPROJ_INPUT_SIZE[3] INTEGER _LAMP_1 = 8 INTEGER _LAMP_2 = 9 cPROJ_CMDS[_PROJ_LAMP1_QUERY] = 'Q$L:1' // QUERY LAMP HOURS cPROJ_CMDS[_PROJ_LAMP2_QUERY] = 'Q$L:2' // QUERY LAMP HOURS ///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// DEFINE_EVENT //////////////////// Projector Control DATA_EVENT[dvPROJ] { ONLINE: { SEND_COMMAND dvPROJ,'SET BAUD 9600,N,8,1 485 DISABLE' SEND_COMMAND dvPROJ,'HSOFF' lPROJ_TIME_ARRAY[1]= lPROJ_LAMP_TIME //START LAMP QUERY TIMELINE TIMELINE_CREATE(iPROJ_TIMELINE_TRACKER[_LAMP_1],lPROJ_TIME_ARRAY,1,TIMELINE_ABSOLUTE,TIMELINE_REPEAT) lPROJ_TIME_ARRAY[1]= lPROJ_POWER_TIME //START POWER QUERY TIMELINE TIMELINE_CREATE(iPROJ_TIMELINE_TRACKER[_POWER],lPROJ_TIME_ARRAY,1,TIMELINE_ABSOLUTE,TIMELINE_REPEAT) WAIT 50 { lPROJ_TIME_ARRAY[1]= lPROJ_LAMP_TIME //START LAMP QUERY TIMELINE TIMELINE_CREATE(iPROJ_TIMELINE_TRACKER[_LAMP_2],lPROJ_TIME_ARRAY,1,TIMELINE_ABSOLUTE,TIMELINE_REPEAT) } } STRING: { LOCAL_VAR char cTrash[50] cPROJ_RX = DATA.TEXT IF(FIND_STRING(cPROJ_RX,'PON',1)) { iProjectorPower = 1; CALL 'SEND_STRING_FEEDBACK'(vdvPROJ,'POWER',ITOA(iProjectorPower)); //FOR RMS Feedback } ELSE IF(FIND_STRING(cPROJ_RX,'POF',1)) { iProjectorPower = 0; CALL 'SEND_STRING_FEEDBACK'(vdvPROJ,'POWER',ITOA(iProjectorPower)); //FOR RMS Feedback } IF(FIND_STRING(cPROJ_RX,'OSH:1',1)) {iProjectorMute = 1 } IF(FIND_STRING(cPROJ_RX,'OSH:0',1)) {iProjectorMute = 0 } IF(LENGTH_STRING(cPROJ_RX >= 3) AND (iPOWER_QUERY_SENT[_PROJ1]=1) ) //Power Query Response { iPOWER_QUERY_SENT[_PROJ1]=0 cTrash = REMOVE_STRING(cPROJ_RX,"$02",1) //Remove up to header IF(LENGTH_STRING(cPROJ_RX) = 4) //I got good data { iProjectorPower = ATOI(MID_STRING(cPROJ_RX,3,1)) } } IF(LENGTH_STRING(cPROJ_RX >= 4) AND (iLAMP_QUERY_SENT[_PROJ1][iLAMP_1]=1) ) //Lamp Query Response { iLAMP_QUERY_SENT[_PROJ1][iLAMP_1]=0 cTrash = REMOVE_STRING(cPROJ_RX,"$02",1) cLAMP_HOURS_RX[_PROJ1][iLAMP_1] = LEFT_STRING(cPROJ_RX,4) SEND_LEVEL vdvPROJ,_TP_LVL_LAMP_HOURS1,ATOI(cLAMP_HOURS_RX[_PROJ1][iLAMP_1]) SEND_COMMAND vdvProj,"'LAMP 1 HOURS=',cLAMP_HOURS_RX[_PROJ1][iLAMP_1]" CALL 'SEND_STRING_FEEDBACK'(vdvPROJ,'LAMPTIME_1',cLAMP_HOURS_RX[_PROJ1][iLAMP_1]); //FOR RMS Feedback //SEND_COMMAND 10001:1:1,"'^TXT-',10,',1&2,',cLAMP_HOURS_RX"; //-Update Lamp hours //Send_Command vdvTP1,"'TEXT11-',ITOA(cLAMP_HOURS_RX[_PROJ1])" } IF(LENGTH_STRING(cPROJ_RX >= 4) AND (iLAMP_QUERY_SENT[_PROJ1][iLAMP_2]=1) ) //Lamp Query Response { iLAMP_QUERY_SENT[_PROJ1][iLAMP_2]=0 cTrash = REMOVE_STRING(cPROJ_RX,"$02",1) cLAMP_HOURS_RX[_PROJ1][iLAMP_2] = LEFT_STRING(cPROJ_RX,4) SEND_LEVEL vdvPROJ,_TP_LVL_LAMP_HOURS2,ATOI(cLAMP_HOURS_RX[_PROJ1][iLAMP_2]) SEND_COMMAND vdvProj,"'LAMP 2 HOURS=',cLAMP_HOURS_RX[_PROJ1][iLAMP_2]" CALL 'SEND_STRING_FEEDBACK'(vdvPROJ,'LAMPTIME_2',cLAMP_HOURS_RX[_PROJ1][iLAMP_2]); //FOR RMS Feedback //SEND_COMMAND 10001:1:1,"'^TXT-',10,',1&2,',cLAMP_HOURS_RX"; //-Update Lamp hours //Send_Command vdvTP1,"'TEXT11-',ITOA(cLAMP_HOURS_RX[_PROJ1])" } } } TIMELINE_EVENT[_LAMP_1] //////////////////// PROJECTOR LAMP QUERY *) { SWITCH(Timeline.Sequence) { CASE 1: {Send_String dvProj,"$02,cPROJ_CMDS[_PROJ_LAMP1_QUERY],$03" iLAMP_QUERY_SENT[_PROJ1][iLAMP_1]=1} } } TIMELINE_EVENT[_LAMP_2] //////////////////// PROJECTOR LAMP QUERY *) { SWITCH(Timeline.Sequence) { CASE 1: {Send_String dvProj,"$02,cPROJ_CMDS[_PROJ_LAMP2_QUERY],$03" iLAMP_QUERY_SENT[_PROJ1][iLAMP_2]=1} } }
