Long Range IR Control from Axcent?
I have a requirement to send IR commands to a light switch, which is some distance away. Obviously the IR blasters have a range of around a foot at best. Is there any way to fire a handheld remote control strength signal from an Axcent2? I've tried running a transistor into a high power IR emitter but with no luck. If you run it directly from the port the current limited means it's no brighter than a stick on blaster...
James
  • shr00m-dewshr00m-dew Posts: 394
    I'm assuming you can't get a wire over to it. They make IR floods, but that's not really designed to make it across a room.
    How about relay's tied into the remote and a power supply to replace the batteries?
    Kevin D.
    James
    Perhaps a DinkyLink?
