NI4100 locks up after telnet session
I got a 4100 with intermittent problems but this is the worst, after a telnet session ICS buss locks up. I get the flashing link led (which is okay because of network activity) Status stays solid, Input stays solid, Output stays solid all 4 cards in frame and 12 com2 cards in the NXF stays solid. Unit won?t accept inputs from the TP. Power cycles clear the problem but cause connectivity issues with other devices. Talked to AMX only advice slide the first three dipswitches up/down on the config switch and cycle the power. Wondering if the ICSNET is going out on this unit.
Have anyone ever lockup a system after a telnet session?
Brian
Brian
Hmmm
that's a new one on me.
You might try reloading the firmware. Also I'd call tech support on this one.
